My OnePlus DR-1 Drone is not charging
  1. shazab_rafiq
    Froyo Apr 11, 2015
    shazab_rafiq , Apr 11, 2015 :
    I just started using it this weekend and after draining the battery I am unable to charge my drone. Followed instructions 1. switched device off 2. plugged into usb on my macbook and into a wall socket but on either of them it does not show the red light indicating its charging. Has anyone else had a similar problem?
  2. ppod
    Jelly Bean Apr 11, 2015
  3. shazab_rafiq
    Froyo Apr 11, 2015
    lol but I only got to use it for like 5 mins
  4. Jeffreyvdv3lde
    Jeffreyvdv3lde , Apr 11, 2015 :
    Does the light on your cable goes on? If not, than your cable is broken. Which means that you'll get your money back by making a RMA at support.
  5. Deactivated User
    Apr 11, 2015
  6. njw2419
    Honeycomb Apr 11, 2015
  7. Jeffreyvdv3lde
    Yes, there is a white light in your cable at the USB port of the cable, this should light up when you're charging your DR-1
  8. shazab_rafiq
    Froyo Apr 11, 2015
    ok so when i switch it to the "on" position i see the red light go on at the end of the USB cable. But when following the instructions and switching it to off then plugging it in, it does come on and I know its not fully charged
  9. shazab_rafiq
    Froyo Apr 11, 2015
  10. Jeffreyvdv3lde
    Hmm, and your DR-1 can't fly? Maybe it comes fully charged out of the factory.
    Edit: Wait on a other answer from a other forum member, or start a case so you get your money back.
  11. shazab_rafiq
    Froyo Apr 11, 2015
    Yes the cable does light up when not connected to the drone, n thanks for the parrot lol
    Deactivated User likes this.
  12. Deactivated User
    Apr 11, 2015
  13. shazab_rafiq
    Froyo Apr 11, 2015
    Yea it did. I used it for a bit and now it wont charge up again
  14. shazab_rafiq
    Froyo Apr 11, 2015
    Thanks may have to do that unless someone knows how to fix this
  15. Jeffreyvdv3lde
    Wow, that is a really big problem. Can you keep the cable in the DR-1 for a few hours. Maybe it starts charging, if not you can always create a RMA.
  16. maansg
    maansg , Apr 11, 2015 :
    First non-spam thread today... Is already filled with spam:( by the way I hope that you can solve the problem;)
    Edit. Could it be a bad battery?
  17. Deactivated User
    Apr 11, 2015
  18. Kapitan Nemo
    Lollipop Apr 11, 2015
    Kapitan Nemo , Apr 11, 2015 :
    That was my best life time expectation for that cheap toy.
  19. caithao
    Donut Apr 11, 2015
    caithao , Apr 11, 2015 :
    Lmfao, I thought the DR-1 Drone was part of a April fools joke? Never thought that they'll sell anything like it....
    SparkkIt likes this.
  20. johnnyjungle
    Ice Cream Sandwich Apr 11, 2015
    johnnyjungle , Apr 11, 2015 :
    Switch it off also switch off the controller, plug in the charging cable, it will light up. Plug the other end into wall plug and leave it for 20mins.
    Uplug and switch on dr-1 then switch on the control. The dr-1 will beep, move the left joystick to the top, it will beep again the move to the bottom it will beep again.
    Your calibrated and ready to fry.
    MasterMind33 likes this.
