20
My OP3 concept.
  1. Baymax
    Starting Point Expert Dec 17, 2015
    Baymax , Dec 17, 2015 :
    Nope. No back FP sensor. Front is better. And there are two stereo front facing speakers on there.
  2. MaxLikesTurtles
    Jelly Bean Dec 17, 2015
    MaxLikesTurtles , Dec 17, 2015 :
    Then try putting both on one side if they're close together.
  3. Baymax
    You suggesting like a Nexus 5X?
  4. Akmeena15
    Froyo Dec 17, 2015
    Akmeena15 , Dec 17, 2015 :
    Not want Samsung or htc design but rest is good.camera placement should be like opo and design also
  5. Baymax
    Not a Samsung design :p is a Baymax design
    Akmeena15 and Bharath HT like this.
  6. Bharath HT
    KitKat Dec 17, 2015
    Bharath HT , Dec 17, 2015 :
    Good job buddy
    You read my mind with Front Concept Render #3.9.Kudos.
    Baymax likes this.
  7. MaxLikesTurtles
    Yeah, that's what I had in mind, only a bit closer to the camera.
  8. MaxLikesTurtles
    The back texture is very unrealistic. It's fading out, implying that it'll flatten out at the sides. What you want instead is for it to get darker. If you're in Photoshop and you have that texture open, you need to paint the sides darker with a soft brush.
  9. Baymax
    Ok. I will see about doing something along these lines.
  10. Baymax
    I'm in After Effects. I was planning on adding a noise then a blur to the back texture. To kinda bring up the effect but not overexpose it.
    aaron.hossain75 and Tokolozi like this.
  11. g kantner
    Cupcake Dec 17, 2015
    SamuraiKitty likes this.
  12. g kantner
  13. Jupeeeeee
    Jupeeeeee , Dec 17, 2015 :
    It's nice overall. But what changes I'd make to it, I'd put the fingerprint sensor on the back since it's on a better place there. Also, i'd make physical home button a uhh... capacitive buttons I think those are called. anyways the two buttons next to the home button, make the home button like them, but not configurable. keep it as a home button. or make it just another configurable button. If you catch what I mean.
  14. Dunnow
    The Lab - OnePlus 6 Reviewer Dec 17, 2015
  15. Baymax
    What else would you call them?
  16. Baymax
    I am not a fan of back mounted fingerprint sensors.
  17. Jupeeeeee
    But still it's just my opinion :rolleyes: I'm no fan of fingerprint sensors overall but since some people like it, meh, couldn't really care less. but the home button on op2, it's just horrible. not only because the fingerprint sensor is under it but it's not like a button you can press. you just put a little weight on it and it gets registers as a push of a button.
    Or might've been that my friends op2 home button was broken somehow. anyways it seems like theres nothing to press and you have no idea if the button is working or not because there is nothing to tell you if you pressed the button or not. Nothing else but the reaction to the press of the "button".
    My english might be messy and not make sense at all, but hey, i'm tired, it's late and only slept a few hours last night.
  18. DS1987SD
    Honeycomb Dec 17, 2015
  19. Dunnow
    The Lab - OnePlus 6 Reviewer Dec 18, 2015
    Dunnow , Dec 18, 2015 :
    not a render... as a render is a simulation of a 3d object... and this is not.
  20. SaltLife
    Ice Cream Sandwich Dec 18, 2015
