MY OPO SIGNAL STOPPED WORKING RANDOMLY
  1. LewisThomas
    Gingerbread Mar 22, 2015
    LewisThomas , Mar 22, 2015 :
    Hey so last night I was using my OPO as usual, loving it as always late into the night. I woke up this morning and it says all I can do it emergency calls, I tried taking the sim in and out. I put the sim into my old phone and it worked fine. I tried rebooting and nothing.
    HELP!!!! I need a fix very soon if anyone can please do so!
    This is what shows up on my screen.
    FIXED
    After posting this thread shortly after my signal came back to life.
    All I did was make sure the setting were all okay in "Mobile network settings" just to make sure and all I did was searched for my network (three) and it didn't find it so I tried again and still didn't find it. I then went to "preferred network type and found that it was on 2G instead of 3G so I changed it then it worked again.
    Hope this helps
  2. 4nlimited3dition
    Jelly Bean Mar 22, 2015
    4nlimited3dition , Mar 22, 2015 :
    I experienced this too.
    It turned out my service provider (DNA) had their network down temporarely.
    No one using their network had any connection until they fixed their problem after some 30 minutes or so.
  3. LewisThomas
    The network isn't down for sure I asked my friends in the same area and as I said tried my old phone with the same simcard and it worked in that.
  4. riicky12
    Honeycomb Mar 22, 2015
    riicky12 , Mar 22, 2015 :
    YOU DON'T HAVE TO USE CAPS IN YOUR TITLE :p
    I don't know why you don't have a signal, never had that myself.
  5. 4nlimited3dition
    Have you tried the SIM card in any other phones?
    Edit, nvm my bad being blind..
  6. riicky12
    Did you read what he said? -.-
  7. LewisThomas
    Yes and it worked in that other phone.
  8. LewisThomas
  9. riicky12
    I think he needs 5 messages before he can create a thread :p
  10. 4nlimited3dition
    Yes and no. I didn't sleep too much last night, so my level of consciousness is literally near zero.
    My bad.
  11. LewisThomas
