My phone's wifi frequently disconnects and reconnects. via OnePlus 7T
  1. Shazaibbhat33
    Cupcake Mar 5, 2021
    Shazaibbhat33 , via OnePlus 7T , Mar 5, 2021 :
    The wifi disconnects and reconnects often which is irritating, sometimes i am browsing and the wifi disconnects its just irritating. I have tried resetting my device/network settings. Didn't help
  2. dilip4
    Eclair Mar 7, 2021
  3. MayurGangwani
    Cupcake Mar 7, 2021
  4. Caomhin
    OnePlus 9 Series Expert Community Expert Mar 7, 2021
    Bobbie63 likes this.
  5. MayurGangwani
    Cupcake Mar 7, 2021
  6. Caomhin
    Caomhin , via OnePlus 6T , Mar 7, 2021 :
    If not set already, also Change the Channels on the router for 5Ghz to below 100 and for 2.4Ghz below 11.
    See if that can help.
    You can also check neighbouring channels using WiFi Analyzer, in case they are causing interference, change your router channel to a channel a neighbour is not on.
    I use this WiFi Analyzer to check my surrounding WiFi broadcasts.
    https://play.google.com/store/apps/details?id=com.vrem.wifianalyzer
    Bobbie63 and Shailender Sharma like this.
  7. MayurGangwani
    Cupcake Mar 7, 2021
    MayurGangwani , via OnePlus 7T , Mar 7, 2021 :
    Already did bro!
  8. Caomhin
    Other than Backing up the phone and doing a full Erase All Data factory reset.
    Only other option would be to contact OnePlus directly.
    You can use one or more options below to send Bug reports on the issues back to the OnePlus OOS developers.
    Feedback tool
    You can also contact bughunters@oneplus.com
    And also contact OnePlus support directly to see if they have more information on your issue. Scroll down the page for contact and online chat details.
