Navigation bar issue in One plus 7t pro via OnePlus Nord
  1. Harish Behera
    Cupcake Apr 12, 2021
    Harish Behera , via OnePlus Nord , Apr 12, 2021 :
    In one plus 7t pro, after android 11 update the navigation bar is not working properly.
    Swiping up from bottom edge of screen I am not able to view the recent apps either and also not able to go to home.
    But left and right swipes from edges are working fine as before.
    Please advice a solution as soon as possible.
    rakesh8588 likes this.
  2. Aaron2017
    KitKat Apr 12, 2021
    Best Answer
    Aaron2017 , Apr 12, 2021 :
    Have you tried clearing cache and/or storage of the launcher? Do note if you clear data you'll have to set your preferences again, the layout, icon pack etc.
    Harish Behera likes this.
  3. rakesh8588
    Cupcake May 6, 2021
  4. the_o2
    OnePlus 9 Series Expert Community Expert May 6, 2021
    the_o2 , May 6, 2021 :
    Just mentioned above your comment :rolleyes:
