Navigation Gestures Improvement
  1. M457ERM1ND
    Donut Dec 29, 2018
    M457ERM1ND , Dec 29, 2018 :
    Hello everyone,
    I like the OxygenOS gestures but they still need some improvements.
    My idea, homescreen gesture:
    Basically when you're on the homescreen (launcher) you wouldn't need to swipe up and hold and then tap the last app used to open it (while the previous recent app is just a slide of your finger away)
    You'd only need to SWIPE UP STRAIGHT from the bottom of the screen and the last app opened will jump onto the screen. (if you hold the app window; then you just open the recent app list) Also if you swipe up and right, you open the previous recent app. (just as now)
    This would make the gestures a lot easier to use, I think
