navigation problem.
  1. ramubujji
    Cupcake Apr 8, 2018
    ramubujji , Apr 8, 2018 :
    navigation was not working properly please help what i do...my location was not wrong.
  2. Nick 59
    Lollipop Apr 8, 2018
    Nick 59 , Apr 8, 2018 :
    Could you give us some more info as I am struggling to understand the problem. Also details like which OS you are using, when issue started, steps you have tried to resolve it etc, etc...
    Help us to help you.
    biplabloveu and shreyasopeth like this.
  3. lostLambda
  4. ramubujji
    Cupcake Apr 8, 2018
  5. ramubujji
    Cupcake Apr 8, 2018
  6. mr.imran
    Cupcake Apr 8, 2018
    mr.imran , Apr 8, 2018 :
    my gps turn inaccurate after upgrade the software..anyone have the same problem? any solution?pls help..i always using..
  7. Ash645
    KitKat Apr 8, 2018
    Ash645 , Apr 8, 2018 :
    clear your cache.
    your GPS may be scrambled from all the navigation.
    try it after your cache is cleared. it should fix it.
  8. mr.imran
    Cupcake Apr 8, 2018
  9. Johnathan Wick
    Honeycomb Apr 8, 2018
    Johnathan Wick , Apr 8, 2018 :
    turn it off then volume down and power button togheter enter password and select language should be something about wipe and clean and then make sure you select wipe cache and reboot
