need 4g only or lte only mode
  1. B1559018022647
    Cupcake Jun 20, 2019
    B1559018022647 , Jun 20, 2019 :
    In my area 4g is little bit weaker. So network fluctuating in between 4g volte to H or E. If we can select lte only mode we can get 4g volte all time.
  2. YRJ
    Marshmallow Jun 20, 2019
    YRJ , Jun 20, 2019 :
    4G LTE only mode would be a redundant feature.
    imagine if you are in a area where there is no 4G you would have absolutely no network and you will lose out on calls and internet facility. 4G only can be a thing in the future possibly after 5G becomes mainstream.
  3. B1559018022647
    As I mentioned, in my area 4g volte signal is a bit weak. That's why I asked for it. Also if I had this feature, then I would have switched back to prefer 4g mode back when there is any chance of no 4g.
  4. LarsDekkers
    Froyo Jun 20, 2019
    LarsDekkers , Jun 20, 2019 :
    It already switches to 4G if possible. So all the times it switches to H or E right now you still have connection while if you have 4G only you would then lose connection completely so in your case the 4G only would be useless right?
  5. Murugan366
  6. Manyeko Sharingan
    Froyo Jun 20, 2019
    Tarun2103, darkarvan and abangjoy like this.
  7. B1559018022647
    4636 method not working. My friends are forgetting that it's a dual Sim phone. So I might opt for voice call on Sim 1 and choose data on Sim 2 or vice versa. In that case no problem of loosing connection as data is in separate Sim from voice...
  8. abangjoy
    Cupcake Jul 2, 2019
    abangjoy , Jul 2, 2019 :
    I'm having same problem here. But after uninstall the 3rd party dialer, and clearing cache default oneplus dialer, the code is valid again.
  9. B1559018022647
    Cupcake Jul 3, 2019
  10. TysonSW
    Froyo Jul 3, 2019
    TysonSW , Jul 3, 2019 :
    As @YRJ already has pointed out, you phone will choose the strongest and best available network. If you phone chooses H or E, this means that there are no 4G present at that location that can be used. Possible because of to many packet errors or to weak signal.
  11. B1559018022647
    Cupcake Jul 4, 2019
    B1559018022647 , Jul 4, 2019 :
    We all are saying the same thing. 4g is weak, but data speed in 4g is better. If it had 4g only mode, I would have selected it. Everyone is bothered with call connectivity. But I might use other Sim with strong 2g or 3g for calling...
  12. TysonSW
    Froyo Jul 4, 2019
    TysonSW , Jul 4, 2019 :
    I'm not talking about call connectivity. I am talking about data packages. If you have to many package drops on 4G, the resulting speed will be H/3G or E/2G. So if 2G or 3G has better reception and less package drops then the phone will change to those because the result will be better than an bad 4G connection.
  13. B1559018022647
    Cupcake Jul 4, 2019
    I just wanted lte only mode along with the existing auto modes. Those who Wishing to keep it in auto mode they are free to do so, but who wants a 4g or 4g or 2g only mode should also get it. It is showing in 4636 method, but not changing. What is the problem in giving the liberty to end users rather that supporting the manufacturer for not providing it.
    I just don't want to listen whether 4g only mode is old or not but for me it will be useful. Thanks
  14. Tarun2103
    Cupcake Aug 16, 2019
    Tarun2103 , Aug 16, 2019 :
    thankyou so much
