Need help choosing a phone.
  1. Chika
    Ice Cream Sandwich Nov 14, 2015
    Chika , Nov 14, 2015 :
    From all said, no better suggestions because phones without issues doesn't exist. So, I suggest you go through user experiences and reviews and make the best out of them all. I'm a proud owner of OPX because it serves me best and opdates are coming. Besides that was my budget phone
    Wishing u good luck:D
  2. geko95gek
    geko95gek , Nov 14, 2015 :
    Yeah defo, I'm so happy op decided to go the smaller form factor way on the OPX. It really is just perfect for me!
  3. Deactivated User
    Nov 14, 2015
  4. You237
    Honeycomb Nov 14, 2015
    You237 , Nov 14, 2015 :
    I really would get that if it had any sort or waterproof cases. It does look good, other than that.
  5. Deactivated User
    Nov 14, 2015
    Lingering likes this.
  6. You237
    No. I need one that is waterproof, because the person who will be using it, has OCD, and sometimes compulsively washes things, if you must know. They are currently using a life proof case.
  7. Deactivated User
    Nov 14, 2015
  8. You237
    No, because it doesn't exist on anything other than iphones for the most part.
    Also, I couldn't even find the otterbox for purchase, even on their website.
  9. Deactivated User
    Nov 14, 2015
  10. You237
    Yeah, I clarified early that that wouldn't work. My OP was edited.
  11. Deactivated User
    Nov 15, 2015
  12. You237
    Honeycomb Nov 15, 2015
    You237 , Nov 15, 2015 :
    Do you think the note 4 is a good deal at 400$?
  13. Deactivated User
    Nov 15, 2015
  14. You237
    It's 400 at Walmart, and has a waterproof case, so I may get that.
  15. Vasu_10
    Donut Nov 15, 2015
  16. Deactivated User
    Nov 15, 2015
  17. You237
    Sure. One sec it doesn't come with the case though.
  18. You237
    #38
  19. Deactivated User
    Nov 15, 2015
    #39
  20. You237
    Yeah, GSM is okay. My provider is AT&TT.
    The disclaimer is on every product from Walmart.
    #40
