[Need Help]Push Notification not working/ high delay on CM12.1 (2QL)
  1. kokjoo89
    Froyo Nov 2, 2015
    kokjoo89 , Nov 2, 2015 :
    Recently i update my phone from CM11S to CM12.1 via OTA.
    First issue encountered is the wakelock, oneplus keep wakeup and battery gone ~20% per hour. After uninstall some apps and using privacy guard to keep google play service from awake.
    Now found out that most of the push notification like whatapps, line, wechat, gmail, etc cant receive push modification on time while phone is lock for awhile. Those notification popup all when i turn on my phone.
    I search with google and found this maybe due to wifi connection issue. Now still testing on mobile data.
    Forum CM12/12.1 bugs thread didn't stated this issue.
    Can anyone help me? any idea?
  2. elanglois
    Lollipop Nov 2, 2015
    elanglois , Nov 2, 2015 :
    Unless you need Android Pay, root your phone and install a ROM that doesn't need you to cripple Play Services
    kokjoo89 likes this.
  3. se7enlyn
    Ice Cream Sandwich Nov 2, 2015
    se7enlyn , Nov 2, 2015 :
    my suggestion is to wipe the whole phone, reinstall using fastboot method.
  4. kokjoo89
    Froyo Nov 2, 2015
    Any suggestion where to start? I'm not good at flash ROM nor fastboot.
  5. kokjoo89
    Froyo Nov 2, 2015
    But im using gmail, youtube, keep, calendar... :oops:
  6. elanglois
    OK ... None of those are Android Pay, so install a newer ROM. The newer ROMs don't have the Play Services bug. There are also mobile data bugs that most ROMs have. I think Sultan's and jgcaap's have it fixed.
  7. se7enlyn
  8. kokjoo89
    Froyo Nov 2, 2015
