Need help to find Notch display
  1. RaulRK1993
    Cupcake Sep 17, 2019
  2. xnutzii
    Lollipop Sep 17, 2019
    xnutzii , Sep 17, 2019 :
    It's not there on OnePlus 7, probably because it uses the same firmware as 7 Pro.
  3. RaulRK1993
    RaulRK1993 , Sep 17, 2019 :
    then how come I enabled it when just updated to Android 10? ....and now it's not seen
  4. DA7801
    Honeycomb Sep 17, 2019
    DA7801 , Sep 17, 2019 :
    xnutzii
    It's not there on OnePlus 7, probably because it uses the same firmware as 7 Pro.​
    There's the option what are you talking about? Lol mate!
    RaulRK1993
    then how come I enabled it when just updated to Android 10? ....and now it's not seen​
    It can be a bug? Restart can solve it or if you're on beta then wait for the update
  5. xnutzii
    Then as mentioned by the other member, it may be a bug.
    Didn't know that, am not owning either 7 nor 7 Pro, so thanks for the clarification.
  6. DA7801
    Well
    There's a common understanding that if someone's replying in the particular device forum he or she must be using the mentioned device
    Please do mention your device before replying to a similar thread to avoid confusion for the user
  7. xnutzii
    You don't need to explain a Lollipop how the forum works.
    I sometimes guess what the issue is, and when asked, if necessary, I mention the device I am using. 6T in this case. There's no "common understanding" by any means. People even help out others that don't own the aforementioned issued device. No bad blood here.
  8. RaulRK1993
    ....I did it, have also installed Android 10 again from System update! I am disturbed because it was shown first and have made Hide the Notch but where is the option now from the setting? ....I will attach again a screenshot of my phone settings, have a look at it
  9. DA7801
    Well
    You got a bit hot there! Chill
  10. xnutzii
    I even said "No bad blood" ): ): ):
