Need help to flash CM12 Nightly Official build
  1. Pratyush
    Gingerbread Jan 7, 2015
    Pratyush , Jan 7, 2015 :
    Can some body please help o flash the CM12 ROm, if you can please share the link which shows the step by step procedure...
    as of now Am using STOCK one
  2. jeffreythomas007
    Eclair Jan 7, 2015
    jeffreythomas007 , Jan 7, 2015 :
    Search for "nevercholt tech" in youtube. His channel has a video that clearly shows the steps to flash it. I hope you are rooted, which is a complusory requirement. Also, search the forum before you post threads like this. Cheers :)
    llcooljerry likes this.
  3. j0hnby
    Froyo Jan 7, 2015
    j0hnby , Jan 7, 2015 :
    And check out the Development section of the forum - there is loads in here to help you flash any rom.
    Pratyush likes this.
  4. Pratyush
    thanks for info.. i have searched for it :) but didnt get a thread which shows step by step or some links for it...
  5. Pratyush
  6. MisterHarshil
    Honeycomb Jan 7, 2015
  7. nitinrana1574
  8. Pratyush
    nope not yet.... if its needed now i will... if u xplain me how to do... am very new to all this
  9. MisterHarshil
    MisterHarshil , Jan 7, 2015 :
    I rooted 2 hours back brother, It's really fast now!
    https://forums.oneplus.net/threads/...-recovery-and-root.64487/page-67#post-8182039
    Follow that thread! Will hardly take 10 minutes to root it :p
    Then once done- follow this tutorial;
    https://forums.oneplus.net/threads/instruction-cm12-nightlies-official.229824/
    Goodluck and let me know how CM12 Is as I have not flashed it yet but only rooted my OPO :)
  10. Pratyush
  11. NaterTots
    Jelly Bean Jan 7, 2015
    NaterTots , Jan 7, 2015 :
    You could. I'd use twrp myself. And you'll need to unlock the bootloader which will completely wipe your phone.
  12. Pratyush
    in other devices with other recovery procedures we can take backup and restore cant we do that here??
  13. jeffreythomas007
    Eclair Jan 7, 2015
    Yes you can backup all your data and apps using an app called "Helium" and then restore it after unlocking the bootloader and rooting. I suggest you follow C4ETech's video on youtube to root your OPO. I did it. Easy and works without any errors. Hope this helped. :)
  14. boggogo
    Honeycomb Jan 13, 2015
    boggogo , Jan 13, 2015 :
    Hi guys. Sorry for the question that is off topic. Do I need to be rooted to get the latest Official CyanogenMod ? :)
  15. cultiv
    Froyo Jan 13, 2015
    cultiv , Jan 13, 2015 :
    If you really need this much help then you should seriously consider if you want to be doing this. Flashing a nightly is not for the faint of heart and if you haven't even googled and tried to do something yourself then you most likely should not be messing around with this. Of course you're free to brick your phone if you want to so.. good luck.. ;)
