Need help to unbrick my OnePlus 7 Pro
  1. RandomDude66613
    Gingerbread May 25, 2019
    RandomDude66613 , May 25, 2019 :
    So I'm probably one of the kind who manage to brick my brand new OnePlus 7 Pro in a first day trying to install twrp, magisk. First I had problems with TWRP seen files on a phone (screenshot #1)
    after numerous attempts of flushing TWRP, mounting storage etc I decided to start all over and lock the boot loader via "All Toll In One". Now I can't boot into bootloader or recovery at all by holding power and volume keys, and all I see now is this message (screenshot #2)
    Now I don't know what to do...
    Jumpi1234 likes this.
  2. Android450
    Marshmallow May 25, 2019
    Hydra Bob likes this.
  3. Hydra Bob
    Hydra Bob , May 25, 2019 :
    Oof you locked the bootloader before the phone was completely back to stock? That's rough.
    If that's the case there's not going to be anything you can do on your own to recover it until someone manages to get their hands on the unbrick tool and share it with the public.
    I'd suggest you contact OP support and start a remote session with one of their techs to reflash your device back to stock.
    Nick 59 and toastytoast1234 like this.
  4. RandomDude66613
    Well, **** me I guess...
  5. RandomDude66613
    well support doesn't do much for me...
  6. Hydra Bob
    Well that's unusual, normally they would bump you up to a level 2 tech who would use the unbrick tool to remotely reflash your device. I wonder if they don't want to risk leaking it so people won't use it to bypass the locks on the T-Mobile version like they did for the 6T. I suppose it wouldn't hurt to try requesting a remote session and if they say no then at least we'll have a definitive answer.
  7. RandomDude66613
    I got it, all I had to do is holding volume up, down and power key at the same time to get to bootloader.
  8. karimshan
    Cupcake May 26, 2019
    karimshan , May 26, 2019 :
    Hey man, what did you do after you got to the bootloader? I'm facing the exact same issue. I de-selected "enable oem unlocking" in settings, then did "fastboot oem lock" and then the same screen with the "your device is corrupt" message is showing up and I can't do anything except get to the bootloader. I tried doing "fastboot oem unlock" but I'm getting an error message, I also tried to do "fastboot erase userdata" erase cache and the "flash-all" from the batch file in the stock GM21AA ROM file but everything I try fails and I can't do anything except be stuck on the "your device is corrupt" screen or the bootloader. Help please.
  9. VinZ6767
  10. VinZ6767
    VinZ6767 , May 26, 2019 :
    You even don't go to Qualcom Crash Mode ?
    The tech told you to only go fastboot mode (power - power + power) ?? That's strange ?
  11. RandomDude66613
    Gingerbread May 26, 2019
    RandomDude66613 , May 26, 2019 :
    Yeah it actually worked
  12. RandomDude66613
    They didn't even told me anything, I was just trying different combinations
  13. RandomDude66613
    But still TWRP didn't see the internal storage
  14. Jumpi1234
    Jelly Bean May 26, 2019
    Jumpi1234 , May 26, 2019 :
    I suggest trying what I did
    1.boot into TWRP
    --> Wipe All data, Yes,
    Go to the other slot,
    --> Wipe all data , Yes,
    then wipe, Internal storage, apps, cache, data
    2.boot into bootloader
    try to download this file=
    " 9.5.3-GM21AA-OnePlus7ProOxygen_21.O.07_OTA_007_all_1905120542_aa37bad-FASTBOOT"
    found in the downloads section of this thread
    https://forum.xda-developers.com/oneplus-7-pro/how-to/rom-stock-fastboot-roms-oneplus-7-pro-t3931424
    after you connect in fastboot, try to perform the flash-all.bat
    after that's done, try to boot once more into recovery
    my device erased some extra things, which made me able to boot.
  15. RandomDude66613
    Holding volume up + volume down + power key, worked for me.
  16. VinZ6767
    I success to go to fastboot mode with Holding volume up + volume down + power key.
    But i cannot flash any file, because it said, cannot flash in 'locked state'.
    I can't go a boot to active partition A which contains TWRP, because the devices is locked)
    What you do exactly or what the tech do ?
    Best Regards,
  17. VinZ6767
    .\fastboot.exe --set-active=a
    > Slot Change is not allowed in Lock State
    .\flash-all-partitions.bat
    Sending 'aop_a' (196 KB) OKAY [ 0.010s]
    Writing 'aop_a' FAILED (remote: 'Flashing is not allowed in Lock State')
    fastboot: error: Command failed
    Sending 'aop_b' (196 KB) OKAY [ 0.012s]
    Writing 'aop_b' FAILED (remote: 'Flashing is not allowed in Lock State')
    So i cannot flash STOCK one plus ROM.... :(
  18. RandomDude66613
    N1557911255668
    So i cannot flash STOCK one plus ROM....​
    I used "All Tool In One" and unlocked the boot loader again
  19. VinZ6767
    Yes but i cannt unlock the boot loader, because i ticked OEM lock in dev settings like an idiot :(
    After that i go fastboot and type ./fastboot oem lock.
    So now i cann't do / fastboot oem unlock :(
    .\fastboot.exe oem unlock
    FAILED (remote: 'Flashing Unlock is not allowed
  20. VinZ6767
    So my phone is really BRICKED and i need to flash stock signed file using MSMDownloadTool and the OP7 Pro Dump.
    I find dump for all one plus except for OP7 Pro which is too new.
    Please can someone provide me OP7Pro Dump flashable in Qualcom Crash Mode or something like that ?
    Oneplus can share me the file and the instruction ? I can do it my self.
    They don't want to get back the device to fix it i hope .... :(
