OxygenOS Need help to upgrade OS with out data wipe
  1. sunil.avvas
    Gingerbread Sep 12, 2019
    sunil.avvas , Sep 12, 2019 :
    Hi everyone, unknowingly I flashed op5 beta build and now there is no support for it, I wish to upgrade or back to stock so Is there a way to upgrade from OP5_O2_BETA_35 to any lastest build with out wiping data??
  2. LegolasX
    Jelly Bean Sep 12, 2019
    LegolasX , Sep 12, 2019 :
    why don't you backup the data before doing so?
    and beta to stable will wipe the device there is no work around.
  3. sunil.avvas
    I have installed many applications which has admin access and if I wipe then I need to start verifications / authentications for many apps(financial/work/personal apps) and also system native apps contains data like voice recorder, system settings etc.
  4. dsmonteiro
    Community Consultant Community Expert Sep 12, 2019
    dsmonteiro , Sep 12, 2019 :
    There is no way.
    As mentioned in the Beta thread, a wipe is mandatory. You can however backup using OnePlus Switch (don't forget to copy the backup before wiping the phone) and then return to stable updates.
