Need question answered asap!
  1. Caveman17
    Ice Cream Sandwich Oct 18, 2014
    Caveman17 , Oct 18, 2014 :
    If I install a rom and wipe data, will the backup stored on my phone be erased???
    Thanks
    Caveman
  2. Hanson Lee
    Marshmallow Oct 18, 2014
    sp99 and Aaroneloy21 like this.
  3. marionij
    Honeycomb Oct 18, 2014
  4. rgb1998
    KitKat Oct 18, 2014
    Hanson Lee likes this.
  5. Caveman17
    Yes, but if I backup then install the rom, will that backup be erased? Can I restore all my apps after installation?
  6. rgb1998
    KitKat Oct 18, 2014
    rgb1998 , Oct 18, 2014 :
    No. Your backup will not be erased after wiping data(in order to install your new ROM). However, if you wipe internal storage before installing the rom, your backup will most definitely be erased. Use titanium backup to backup all your apps before the ROM installation and then you can restore after the ROM installs.
    Caveman17 likes this.
  7. Caveman17
    I have. When I wipe data, will it get erased?
  8. rgb1998
    KitKat Oct 18, 2014
    See my above post.
  9. Caveman17
    So the wipe will not affect the titanium backup folder either?
  10. Aaroneloy21
    Jelly Bean Oct 18, 2014
  11. rgb1998
    KitKat Oct 18, 2014
    If you change your backup path to "/Internal Storage" when you back up then it won't.
  12. dcoulombe
    dcoulombe , Oct 18, 2014 :
    Just to be on the safe side, copy those backups to a computer or cloud service. I erased backups in the past by mistake (wiped sdcard) and was glad I had backups elsewhere.
    You can used adb pull in recovery. It's slow, but it works.
  13. sp99
    Community Veteran Oct 18, 2014
    sp99 , Oct 18, 2014 :
    Unlocking the bootloader will! ;)
    And flashing a ROM, you'll lose all your apps! :D
    Do some research first though! :p
    Caveman17 and Hanson Lee like this.
  14. Caveman17
    Aaroneloy21 likes this.
  15. sp99
  16. abhibhan89
    KitKat Oct 18, 2014
    abhibhan89 , Oct 18, 2014 :
    The recovery stores the backups in the recovery folder itself..
    And when you do a complete wipe using the recovery, it doesn't wipe itself out..
    So, I'm guessing that the backup should be safe..
    PS: Not sure although..
  17. Aaroneloy21
    Aaroneloy21 , Oct 18, 2014 :
    Man that sucks to hear.. Try progressive they have a lot of commercials these day!!
  18. Caveman17
    So if I make a titanium backup, it will still be there after erasing data?
  19. jcespi2005
    jcespi2005 , Oct 18, 2014 :
    wipe data just erases /data partition (where apps and system saves data), but don't touch the internal storage, where usually Titanium storage the backups.
    dcoulombe likes this.
  20. Ycantibeu21
