Need Replacement Charger
  1. zahinullah
    Cupcake Aug 22, 2014
    zahinullah , Aug 22, 2014 :
    Recently got the phone and lost the charger base on a trip..Does anyone know of where I can get an OEM charger?
    Thanks
  2. givemeyoursoul
    KitKat Aug 22, 2014
    givemeyoursoul , Aug 22, 2014 :
    Any 2amp 5v USB charger I think.
    ajstar7, Skf123 and drmartin like this.
  3. Seanado
    Donut Aug 23, 2014
    Seanado , Aug 23, 2014 :
    Stepped on my charger earlier, one of the prongs has been bent out. Now i need to know:
    if the casing for the charger can be opened up to repair the charger and;
    what voltage charger should i use in the meantime as a temporary replacement?
    please respond, very urgent.
  4. drmartin
    Lollipop Moderator Aug 23, 2014
    drmartin , Aug 23, 2014 :
    Read there. ;)
    I found that the Note 3 charger is more or less identical to the OPO, so you could probably use that. They are a little more available.
    givemeyoursoul and Skf123 like this.
  5. Skf123
    Marshmallow Aug 23, 2014
    Skf123 , Aug 23, 2014 :
    As already said 5v voltage
    CrazedCoder likes this.
  6. ikutoisahobo
    Ice Cream Sandwich Aug 23, 2014
    ikutoisahobo , Aug 23, 2014 :
    Any micro-USB charger will work. Most are of a standard voltage, and if it's less voltage then it will charge slower but no damage will be done.
  7. chongswee
    Jelly Bean Aug 23, 2014
  8. Seanado
    Donut Aug 23, 2014
  9. givemeyoursoul
    KitKat Aug 23, 2014
    givemeyoursoul , Aug 23, 2014 :
    But will charge slowly. Most USB charge at 1amp.
  10. chongswee
  11. chongswee
  12. minhduy223
    Froyo Aug 23, 2014
    minhduy223 , Aug 23, 2014 :
    well you could go to any electronic store or just buy 2 AMP USB charger off amazon
  13. hotsauce
    Lollipop Aug 23, 2014
  14. PoPSiCLe
    Donut Aug 27, 2014
    PoPSiCLe , Aug 27, 2014 :
    Actually first time I've ever seen not one single available charger on eBay, Alibaba, *********** or anywhere...
  15. Zhukov45
    Gingerbread Sep 10, 2014
    Zhukov45 , Sep 10, 2014 :
    Why bother? It's not worth trying fix it considering a new charger will only run you about $10.
  16. Haymond
    Ice Cream Sandwich Sep 10, 2014
  17. Zachsaxe
    Lollipop Sep 10, 2014
    Zachsaxe , Sep 10, 2014 :
    My Samsung s4 charger was the same as the opo charger
  18. jackasswhole62
    Donut Dec 7, 2014
    jackasswhole62 , Dec 7, 2014 :
    Buy a blackberry playbook charger from ebay. It sells only cheap price. And charging time is very good. And the bonus is you have a long wire cord not like the original which is short.
    pablogsm91 likes this.
  19. balinortx
    Cupcake Dec 23, 2014
    RadioCult likes this.
