[Submitted] Netflix won't load on Open Beta 5 with L1 fix
  1. Green_1
    Gingerbread Mar 29, 2018
    Green_1 , Mar 29, 2018 :
    Netflix won't start, gives error -9
    This phone has had the widevine L1 patch applied.
    Works properly if I disable L1 by renaming /system/vendor/lib/liboemcrypto.so (though won't do HD that way)
    david19au likes this.
  2. david19au
    Cupcake Apr 15, 2018
  3. Deactivated User
    Apr 18, 2018
  4. david19au
    Cupcake Apr 22, 2018
    david19au , Apr 22, 2018 :
    Negative, I run OOS 5.0.4 with root and unlocked bootloader and Netflix works just fine with L1
  5. Deactivated User
    Apr 22, 2018
  6. david19au
    OOS 5.0.4 is not OB8 or OOS 5.1.0... OOS 5.0.4 is still on Android 8.0 whilst 5.1.0 or OB6,7,8 are on Android 8.1. On Android 8.0 you can normally have Netflix with L1 while being rooted. On 8.1 you have to disable L1 playback, in order to use Netflix.
  7. Deactivated User
    Apr 22, 2018
