10
[Submitted] Network and wifi disconnected
  1. buddow
    Eclair Nov 19, 2019
    buddow , Nov 19, 2019 :
    Hi, If i turn on the location services on my phone the network is randomly disconnected for a few seconds on both sims, including Wifi and 4G. I am using this phone also with a work profile. For some users, turning off locations services helps to solve this and for some it helps to disable work profile. Of course this means we can't use full functionality and this is a bit disappointing. This bug is reported since the Android 10 update.
  2. jaymaru
    Donut Dec 3, 2019
    jaymaru , Dec 3, 2019 :
    Same issue on 7T. Issue happens when work profile is enabled and an app that is location based (e.g. google maps, citymapper) is used
    Nancybruggeman, diwa51 and FirespeedA like this.
  3. Nancybruggeman
    Cupcake Jan 25, 2020
    Nancybruggeman , Jan 25, 2020 :
    Same here!
    Is there a fix known since the issue appears? I see on the community that it frequently happened in december, not now anymore
  4. H1580187922096
    Cupcake Jan 28, 2020
    H1580187922096 , Jan 28, 2020 :
    Hi there...post an 10 update im also facing terrible issues with NW connectivity which i dont face on my old android phone. Can anyone please help me with the solution
  5. Y1574942718338
    Cupcake Feb 18, 2020
  6. G_Jordan_A.F._YCdq
    Cupcake Feb 19, 2020
  7. jatinramani095
    Cupcake Feb 20, 2020
  8. buddow
    Eclair Feb 21, 2020
    buddow , Feb 21, 2020 :
    Last ROM update also doesn't fix. When can we expect a solution? This is taking too long.
  9. Nancybruggeman
    Cupcake Feb 26, 2020
    Nancybruggeman , Feb 26, 2020 :
    The problem is solved with the last update. Thanks
    buddow likes this.
  10. buddow
    Eclair Feb 27, 2020
    buddow , via OnePlus 7 Pro , Feb 27, 2020 :
    Which update exactly? I still experience issue with 10.0.4 EU
  11. jaymaru
    Donut May 22, 2020
  12. G_Anil_Casey_ppll
    Cupcake Jun 17, 2020
    G_Anil_Casey_ppll , Jun 17, 2020 :
    same issue with me suddenly wifi gets off and then reconnect please suggest what should I do do I wipe out my phone or wating for new update to fix this problem
