Network Drops on every Nougat based ROM for Oneplus 2
  1. NKLRWT
    Froyo Nov 21, 2016
    NKLRWT , Nov 21, 2016 :
    Okay, So i have a real issue here. So i flashed the CM14.1 and i have 2 sims- Vodafone and Jio, but alot of the times, both the Sims loose their networks. I have selected GDM for Voda and LTE for Jio so that jio internet works. But i am constantly losing network. even between calls or whenever i cut a call, the networks from BOTH the sims disappear. Any particular solution to it?
    P.S THIS PROBLEM ISNT JUST FOR CM 14.1... BUT WHENEVER FLASH A NOUGAT BASED ROM I.E 7.0 OR 7.1, EVERYHING WORKS BUT NETWORK DROPS OCCUR SO FREQUENTY.
    PLEASE HELP ASAP
    vaibhavshah96 likes this.
  2. vaibhavshah96
    Cupcake Dec 6, 2016
    vaibhavshah96 , Dec 6, 2016 :
    i too am facing the same problem with jio and airtel
  3. andy9134
    Donut Dec 24, 2016
  4. waseemmayaa
    Donut Jan 19, 2017
    waseemmayaa , Jan 19, 2017 :
    same issue with me on all Nougat Roms.
    if you have found any fix then tell here to all who are facing network drop issue.
    thanks.
  5. kmjraj
    Cupcake Feb 9, 2017
    kmjraj , Feb 9, 2017 :
    the network drop issue has come up on.my phone after installing OXYgen 3.5.6 update. please help as the phone is unusable right now.
    thanks,
    Jayraj
  6. asish.pikun
    Froyo Jun 12, 2017
  7. kanagadeepan
    KitKat Jun 12, 2017
  8. Abhishek Janntwal
    Cupcake Jul 17, 2017
  9. anandsabne
    Cupcake Aug 9, 2017
    anandsabne , Aug 9, 2017 :
    Same issue with me on all the Nougat based ROMs. I tried using AICP, AOSCP Cypher OS, Resurrection Remix 5.8.3 but all the ROMs have same issue of network drop and I even posted this issue on all ROMs' G+ pages, but no one suggested any solution. I'm using Jio and Tata Docomo sim.
