network issue
  1. VinuBest
    Cupcake Oct 17, 2019
    VinuBest , Oct 17, 2019 :
    while playing online games on mobile data suddenly the range of second sim goes off and the sim with internet connectivity doesn't work properly.what should i do??
    Sriharsha1608 likes this.
  2. Waveform Modifier
    Marshmallow Oct 17, 2019
    Waveform Modifier , Oct 17, 2019 :
    Ask your provider
  3. Malg220
    Ice Cream Sandwich Oct 17, 2019
    Waveform Modifier likes this.
  4. VinuBest
    but why it is happening only while playing the games.. otherwise it works smoothly
  5. stark2991_PL
    KitKat Oct 18, 2019
    stark2991_PL , Oct 18, 2019 :
    How do you know? The game needs constant connection, so every deviation will be clearly seen. When browsing you are just waiting for the page to download and that's all, there is no need for a constant connection so it's harder to spot any issues.
  6. VinuBest
    Cupcake Oct 21, 2019
    VinuBest , Oct 21, 2019 :
    what should i do now?
  7. stark2991_PL
    KitKat Oct 21, 2019
    stark2991_PL , Oct 21, 2019 :
    Check on wi-fi.
    Check on different SIM card, preferably from another carrier.
    Do a factory reset if you don't mind losing your data and setting everything up again.
