Network issue via OnePlus Nord
  1. N1603268364747
    Cupcake Nov 30, 2020
    N1603268364747 , via OnePlus Nord , Nov 30, 2020 :
    Most of the time when i open google and search something it shows network is not available,and thia has been keeps on happening ,i have to searc atleast 5 to 6 times to get the result why is this happening and i have also seen many other customers are also facing the same issue ,please reply
    Mumbanish likes this.
  2. Rajendra.Bhat
    Jelly Bean Nov 30, 2020
    Rajendra.Bhat , Nov 30, 2020 :
    Poor network may cause this issue. Check whether Unrestricted data access is enabled.
  3. MPGH
    MPGH , via OnePlus Nord , Nov 30, 2020 :
    Mine as well. I have full internet signal but still facing the same problem many times. It happens when I use Google, Google Map, Line, and mobile banking app.
    I use other device at the same time with the same app and it works fine.
  4. #4
  5. N1603268364747
    Cupcake Dec 6, 2020
    N1603268364747 , via OnePlus Nord , Dec 6, 2020 :
    I have checked and changed also,it worked fine for one day but then it started happening again
  6. avil25
    Honeycomb Dec 6, 2020
  7. N1603268364747
    Cupcake Dec 6, 2020
    Will it be solved ?? And i am also facing issue while making a conference call,first of all as i start the conference call it disappears from screen which means i am able to do it bt can't disconnect any specific call or any call because i see home screen only i dnt see options on screen
  8. avil25
    avil25 , via OnePlus Nord Blue Marble , Dec 6, 2020 :
    It should be solved but the question is when.
    The problem with confrence call is related to google phone app so OnePlus can't do anything in that. I don't do any conference call so don't know whats your problem is.
  9. N1603268364747
    Cupcake Dec 6, 2020
    I dnt knw what happens during call, it always happens, everything disappears during conference call,i can use any app, but i dnt see any option related call disconnection,call swap, recording nothing,just home screen
  10. #10
