Network issue via OnePlus 8T Lunar Silver
  1. AtHarV2562 , via OnePlus 8T Lunar Silver , Dec 2, 2021 :
    My primary sim internet is not working properly I have checked in another phone too but probelm is in my device only
    I want a solution on this problem
    Does anybody experienceing this probelm
  2. pablofg1978
    Head Moderator Head Moderator Dec 2, 2021
    pablofg1978 , Dec 2, 2021 :
    Check the apn settings with your carrier support
    Shailender Sharma likes this.
  3. #3
  4. pablofg1978
    Can you please specify what problems do you have?
  5. AtHarV2562 , via OnePlus 8T Lunar Silver , Dec 2, 2021 :
    Sir my primary sim is airtel and I have internet problem with this sim.
    I have checked my sim twice but there is no problem in my sim the probelm is in my device.
    I have checked this sim in other phones also and it is working properly.
    It is happening since 2 months.
    Do you any solution on this problem?
  6. pablofg1978
    You still don't specify what problems you have.
  7. AtHarV2562 , via OnePlus 8T Lunar Silver , Dec 2, 2021 :
    My problem is my internet is not working properly
    My internet stops working for half an hour for every one hour working
  8. pablofg1978
    Do you have signal at that time?
  9. #9
  10. pablofg1978
    Did you change the preferred network to 4g only?
  11. #11
  12. pablofg1978
    I suggest you to reset your network settings, you should not change the preferred network
