Network Issue
  1. Arshad Sherasiya
    Eclair Jan 12, 2018
    Arshad Sherasiya , Jan 12, 2018 :
    After OxygenOS 5.0 I am experiencing a wierd issue.
    While calling any number, I have to wait for 20-30 seconds before it connects...!
    It has not been fixed even after 5.0.1.
    Please help
    Q1515924310931 likes this.
  2. Gav_W86
    Starting Point Expert Jan 12, 2018
    Gav_W86 , Jan 12, 2018 :
    What network & country?
  3. akku_aakaa
    Gingerbread Jan 12, 2018
  4. manish9584
    Cupcake Jan 12, 2018
  5. Arshad Sherasiya
    Eclair Jan 12, 2018
  6. Arshad Sherasiya
    Eclair Jan 12, 2018
    no.....facing for vodafone also. I think it is not SIM related issue. it is software issue.
    deepsP likes this.
  7. Arshad Sherasiya
    Eclair Jan 12, 2018
    deepsP likes this.
  8. deepsP
  9. cashilpidaga
  10. Gav_W86
    If you are on Jio, check if you have the MyJio app installed. If you do, uninstall it and reboot. That should fix it.
  11. manish9584
    Cupcake Jan 13, 2018
    manish9584 , Jan 13, 2018 :
    I have updated the myjio app and problem is solved. Other than this issue I didn't face any problem after the Oreo update.
  12. cashilpidaga
    Cupcake Jan 14, 2018
  13. cashilpidaga
    cashilpidaga , Jan 14, 2018 :
    called OnePlus technical support and they advice to reset network setting
    setting
    backup & reset
    network reset
    then reboot phone
  14. Arshad Sherasiya
    Eclair Jan 16, 2018
  15. Arshad Sherasiya
    Eclair Jan 16, 2018
    Arshad Sherasiya , Jan 16, 2018 :
    yes. my problem also got solved.I uninstalled my JIO app and reinstalled it. problem solved
