2
Network issue
  1. kohli2825
    Eclair Jun 20, 2018
    Srikantha.r and badulla.p like this.
  2. sdesai264
    Eclair Jun 20, 2018
  3. Anuraj26
    Gingerbread Jun 20, 2018
  4. DhrX
    Cupcake Jun 20, 2018
    Ashvin_Borkar and Srikantha.r like this.
  5. Dadapeer pathan
    Froyo Jun 20, 2018
    Dadapeer pathan , Jun 20, 2018 :
    I have also same issue after this update 5.1.8
    when I was in call suddenly call will be not hear while I am in call
    plz help me from this issue
  6. kohli2825
    Eclair Jun 20, 2018
    kohli2825 , Jun 20, 2018 :
    Ive tried voda...airtel....same issue with both the sims....not reachble....call drop
  7. kogantiu
    Cupcake Jun 21, 2018
    kogantiu , Jun 21, 2018 :
    for me, network bar goes nil, even there have a strong network area. especially in sim 1 only
  8. afroysland
    Srikantha.r likes this.
  9. Srikantha.r
    Cupcake Jul 19, 2018
    Srikantha.r , Jul 19, 2018 :
    same here network issue
    also showing 3g icon instead of 4g symbol.
    i am planning to return this.
  10. Jithendra
    Jithendra , Jul 19, 2018 :
    I got OnePlus 6 yesterday and I am not able to make or receive calls. though network is showing , calls are not going and am getting no mobile networks. wat needs to be done ? disappointed with OnePlus 6.
  11. Thomas.Shine
    Donut Jul 19, 2018
    Thomas.Shine , Jul 19, 2018 :
    even I am facing the very same issue, in Bangalore on Airtel. in my case it work for some time and then stops for next 5 to 8 hrs. no incoming or outgoing doing
    it says mobile.network not available. highly disappointed...
  12. sabbyjay
    Honeycomb Jul 19, 2018
    sabbyjay , Jul 19, 2018 :
    After the 5.1.9 update my Op6 has issues with connectivity as well, the 4G connection keeps going in and out.
    Ot would show 4G sign one second and next second go away. Then a few seconds later the 4G sogn comes back and then few seconds later it will go away.
    I had to manually select the network. For now it's working.
  13. vbhaska7
    vbhaska7 , Jul 19, 2018 :
    Exactly same issue. Changed to new SIM still no luck. Spoke with Airtel and they said its not their problem. Spoke with Oneplus this morning and raised a complaint and they acknowledged that this is a widespread issue with Airtel and promised a fix in couple of days-Still we cant make calls which is the primary purpose of a phone...duuuh.....I also raised a bug ticket + I also did a Oxgen OS upgrade (via VPN)..Still no luck...Suddenly it works and then it stops...No idea
