Network issues with oneplus 8T on screen lock via OnePlus 8T
  1. dinkar19
    Cupcake Dec 15, 2020
    dinkar19 , via OnePlus 8T , Dec 15, 2020 :
    There's an issue with network on my oneplus 8T
    Whenever i lock the screen, no matter i am on mobile data or on wifi
    1. Google assistant doesn't work. It wakes up on saying ok google but it can't help and says sorry you are not connected to network even when wifi and or mobile data is on and working properly. If i just unlock the phone and start using same, it works perfectly
    2. I have noticed, sometimes I misses the notification when screen is locked. Same situation, the Network is not working. The moment i unlocked the phone, all the notification from different apps came all at once.
    anyone facing same ?
    I'm on Oxygen Os 11.0.5.6 KB05AA
  2. Shailender Sharma
    Marshmallow Dec 15, 2020
    Shailender Sharma , Dec 15, 2020 :
    Google assistant doesn't work and Notifications received simultaneously for all apps has been reported by couple of users earlier. Try Don't Optimise for these apps.
    Go to -
    Settings - Apps and Notifications - App Name - Advanced -
    Battery Optimisation - Select Don't Optimise
    Follow the steps for Google assistant and other apps where you are facing issues. If problem still persists use -
  3. dheerajkumar17
    Cupcake Jan 27, 2021
