Network/Connectivity Network Issues
  1. GoldToedJake
    Cupcake Oct 25, 2021
    GoldToedJake , Oct 25, 2021 :
    I updated my OnePlus 6 to Oxygen OS 11.1.1.1 on October 4th. Since then, I have been unable to send or receive MMS messages from my text messaging app. Additionally I am unable to use any applications that require a network connection. As a result, I am unable to use applications such as Chrome Google or any social media apps that require network connection unless I have Wi-Fi.
    I have tried contacting my service provider, contacting OnePlus and have a Case ID: (211005-0023), I've tried doing a factory reset of my phone, and nothing I have tried has resolved the issue.
  2. Caomhin
    OnePlus 9 Series Expert Community Expert Oct 26, 2021
    Caomhin , via OnePlus 9 Pro , Oct 26, 2021 :
    Check the Network APN in Settings, WiFi & Network, Sim & Network Sim 1 or 2. Make sure they match the APN settings from you Mobile Network provider.
    Tokolozi likes this.
  3. GoldToedJake
    Cupcake Oct 26, 2021
    GoldToedJake , via OnePlus 6 , Oct 26, 2021 :
    I did do this with my network provider and was still not able to resolve the issue. :/ I will try it again now that I did a factory reset.
    Caomhin likes this.
  4. GoldToedJake
    GoldToedJake , Oct 26, 2021 :
    Hello again!
    I was able to find a forum on here about the issue I was having and found the answer. I had to change the MVNO type to IMSI and now the MMS messages work again.
    Thank you for your time!
    Caomhin likes this.
  5. Caomhin
    Glad to hear you got it resolved 👍
