Network issues
  1. guruhere7
    Cupcake Oct 27, 2021
    guruhere7 , Oct 27, 2021 :
    I used to get network for sim1 and sim2 at the same time. Recently I had to replace the sim 1 with new one, post which I stopped getting both the network simultaneously. both the sims are working fine as per the operators. so is it something to do with my phone ?
    pls advise.
    Regards,
    prasad
  2. Waveform Modifier
    Marshmallow Oct 27, 2021
    Waveform Modifier , Oct 27, 2021 :
    The 5 series do not support dual active data usage from both network
  3. guruhere7
    Cupcake Oct 28, 2021
    guruhere7 , Oct 28, 2021 :
    Yes I understand we cannot activate 2 data at a time. I keep sim 1 for calls (ask everytime before call) and sim 2 for data.
    Both the network bar shows with full network. if you check the screenshot I attached one bar shows w/o network. This was not the case before.
    L1632672803753 likes this.
  4. guruhere7
    Cupcake Nov 1, 2021
