network issues
  1. svhegne
    Cupcake Feb 20, 2018
    svhegne , Feb 20, 2018 :
    facing too much problem of network.
    asked one of my friend using OnePlus 5t
    he is also facing same issues..
    same network in other mobile, network quality is good but not in OnePlus 5t
    please suggest what to do
  2. Bazz7777777
    Froyo Feb 20, 2018
    Bazz7777777 , Feb 20, 2018 :
    I'm the same since Oreo update me signal is worse, I'm thinking about doing a complete wipe and hope this will help me
    svhegne likes this.
  3. svhegne
    sir I have done that to but no changes..
  4. Bazz7777777
    Froyo Feb 20, 2018
    ok thank you for information, I will try plan b then and flash beta 3 on see if that will make any difference
  5. V_vGoo
    Eclair Feb 20, 2018
    V_vGoo , Feb 20, 2018 :
    currently on a train and basically I've had. 1 minute so far of Signal, even though I know the signal is currently existing my phone will either not provide data and say network available or just flat out network unavailable.
    bit rubbish
  6. svhegne
    friends what's the further process
  7. V_vGoo
    Eclair Feb 20, 2018
    wait for a update I guess , it's a battery saving measure
    svhegne likes this.
  8. PokiX
    Jelly Bean Feb 20, 2018
    PokiX , Feb 20, 2018 :
    I do have times when it takes a minutes to catch network (in badly covered place), I do have times when it takes 30s to ring. And I do have times when I'm the only one getting signals among Samsung and iPhones phones.
    You probably need to change the radio file which means change OS version for a try.
  9. V_vGoo
    Eclair Feb 20, 2018
    there is a bug for sure it's not necessarily just a timeout issue.
    for instance there was one time where restarting my phone meant I got better Signal whilst sat in one place , I noticed this when my friend on the same network was getting better speeds than I was and I was barely able to load a page
  10. PokiX
    Annoying but.. not uncommon on some phones (just had this in an A5 2017 yesterday). Although never had to on the 5T myself.
    Hard to spot like this without a logfile.
    Was it working before an update? Does it happen in different places and different operator?
