3
Network problem in One Plus One!
  1. Bipin parackal
    Gingerbread Jan 30, 2015
    Bipin parackal , Jan 30, 2015 :
    Anyone having problem in network in one plus one?
    My Airtel connection showing unstable signals, anybody else having this problem?
    ravi_opo, Chitkala and vasu131297 like this.
  2. cantthinkofany
    Cupcake Jan 30, 2015
    cantthinkofany , Jan 30, 2015 :
    Put the SIM card in another phone and check. Such network issues are rare. It could be the service provider than the handset.
    Try putting the SIM in at least two three other devices to evaluate the issue.
    Did you get a new Micro sim or did you cut the card?
    There could be issue because the card was not cut properly.
    rahuldborse and Bipin parackal like this.
  3. gauravth
    gauravth , Jan 30, 2015 :
    Actually my OnePlus One is showing better signals and working fine on Airtel Delhi network. Might be issue with sim card check with other handset and if problem still persists get ur OPO to a doctor.
  4. Bipin parackal
  5. apoorva611994
    Bipin parackal likes this.
  6. SaintAlex
    SaintAlex , Jan 30, 2015 :
    try changing the network mode to 3g from LTE and then check.
  7. sumbul ismail
    Cupcake Mar 23, 2015
    sumbul ismail , Mar 23, 2015 :
    Y
    Yes I am facing similar problems in my oneplus one idea connection. :(
    saisudhaA likes this.
  8. pratheesh1983
    Cupcake Mar 30, 2015
    pratheesh1983 , Mar 30, 2015 :
    Yes am facing the same problem, I got this phone cpl of days back thru Amazon India, I cut the sim but have noticed the network is not stable. I tried a option of changing network from LTE to 3g but still issue is persists. Could any one help with a solution ?
  9. sahil bhayana
    Honeycomb Mar 30, 2015
    sahil bhayana , Mar 30, 2015 :
    Tick 2g at place of 3g maybe that solve ur problem
  10. pratheesh1983
  11. Parasskhanna08
    Eclair Mar 30, 2015
  12. vikijen86
    Cupcake Apr 1, 2015
  13. mreddy
    Gingerbread Apr 2, 2015
  14. sajeed
    sajeed , Apr 2, 2015 :
    Ya m facing d same problem some times may b once in a day the network goes n then have to manually search n select d carrier m using airtel.......... Is this related to the latest update??
  15. sahil bhayana
    Honeycomb Apr 2, 2015
    sahil bhayana , Apr 2, 2015 :
    Try it on other sim
  16. sri.bidya1
    Donut Apr 18, 2015
  17. swapnali.jadhav20
    Cupcake Apr 21, 2015
    swapnali.jadhav20 , Apr 21, 2015 :
    I am having same problem with Airtel. It works better in another phone. Signal doesn't remains even if i choose it manually. How to upgrade Mob?
  18. sivakumarreddy
  19. psandee
    Cupcake Apr 22, 2015
  20. sri.bidya1
    Donut Apr 22, 2015
    sri.bidya1 , Apr 22, 2015 :
    Same problem with me for Airtel. So i want to know then problem is in SIM or OPO because bother than OPO in other mob it's working fine.
