2
Network Problem - Wifi & Mobile Data Turns off Automatically
  1. L1569683387559
    Cupcake May 20, 2020
    L1569683387559 , May 20, 2020 :
    Hi Team,
    Since the last update I'm facing network problem on my device. One Plus 6
    System Update says I'm in 10.3.3 Version (Probably the latest Update)
    1 Network turns off and says as No Sim Card
    2 Can't Connect to Wifi Not sure what's the problem
    3 After Restarting the device multiple times the network comes again.
    4 Atleast 4 times in a day I do restart the device because of network problem
    5 It's a critical Issue and needs to address ASAP
    6 Working From with these challenges is not acceptable
    Hope you will work on this issue with priority
    raktimroy121 and T1594739447369 like this.
  2. Artemus.
    Nougat May 20, 2020
    Artemus. , May 20, 2020 :
    When is the last time you formatted?
  3. RogerOriginals
    Ice Cream Sandwich May 20, 2020
  4. L1569683387559
    T1594739447369 likes this.
  5. Artemus.
    Nougat May 20, 2020
    Caomhin likes this.
  6. L1569683387559
    I did these steps,Will wait and see for some days for this issue
  7. Aman2601
    Cupcake May 22, 2020
    Aman2601 , May 22, 2020 :
    I am also facing exactly same problem from many days
    after the recent update the frequency of the problem has increased 5-6 times per day before this problem was once a week problem.
  8. G_Léo_Baumann_pHFE
    Cupcake Jun 20, 2020
    G_Léo_Baumann_pHFE , Jun 20, 2020 :
    Hello,
    I'm having the same problem since 10.3.2 through to 10.3.4 currently.
    I've tried a full wipe, even a fresh install with msmdownloadtool and other ROM that oxygenos (lineage 17.1) and the problem is still present.
    I did not try rolling back to earlier versions of OOS but I will if it is not fixed (not being reachable is a big no no)
    Is it possibly a modem firmware issue since it seems to be crashing everything at the same time (WiFi, data and GPS) ?
    The fact that it happened for several people on the same device / OS version seems to show it might not be hardware related as I feared.
    Cheers
    gogmagog and T1594739447369 like this.
  9. raktimroy121
    Cupcake Jun 30, 2020
    raktimroy121 , Jun 30, 2020 :
    Hi,
    I am also facing the same problem after the android 10 update on my OnePlus 5. I have gone through all the wifi settings, but nothing seems to work.
    Edit: This problem seems to happen with 5ghz wifi not with 2.4ghz wifi.
  10. sezhoo
    Cupcake Jul 4, 2020
    sezhoo , Jul 4, 2020 :
    Similar problem. Mobile data turns off on its own. I can toggle it back on, but periodically it shuts off again.
    Also, this is a consumer device and "format" is an unacceptable solution. System and OS updates should be vetted and patched if necessary and nothing should require an onerous "fix" that costs me time and (potentially) data. That's BS.
  11. T1594739447369
    Cupcake Jul 14, 2020
    T1594739447369 , Jul 14, 2020 :
    Even I have the same issue after the last update. Oneplus should give some bug update soon to avoid such problem.
    1. Network goes automatically
    2. WiFi gets disabled
    3. Sometimes screen gets stucked and phone switches off and on.
    I tried all the things I can do like formatting, cache wipe, hard reset. Nothing is working.
    Solution must be provided from Oneplus and that also very soon.
    raktimroy121 likes this.
  12. AngelNatal
    Cupcake Jul 22, 2020
    AngelNatal , Jul 22, 2020 :
  13. gogmagog
    Cupcake Aug 1, 2020 at 11:08 AM
    gogmagog , Aug 1, 2020 at 11:08 AM :
    Same issue here after update, oneplus 7
    Keeps draining my battery as it's constantly switching and looking for networks
  14. Caomhin
    Lollipop Aug 1, 2020 at 12:11 PM
    Caomhin , via OnePlus 6T , Aug 1, 2020 at 12:11 PM :
    Reset your WiFi adapter, see if that helps.
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth.
    If your router is capable of 2.4ghz and 5ghz make sure the SSID Name for each is different, you can edit the SSID Name on the Router Admin page.
    Also check your router broadcast channels for interference, change them to other channels if you find a nearby router broadcasting on the same channel as yours.
    Use a WiFi analyzer to check.
    I use this one from the Playstore to check for nearby routers using the same channel as me, and I switch my channel on the router to suit.
    https://play.google.com/store/apps/details?id=com.vrem.wifianalyzer
    Also a suggestion here for 8 Series but some of the suggestions may crossover to 6 series and others.
    https://forums.oneplus.com/threads/my-findings-of-the-5-ghz-wifi-connection-issue.1221263/
