Network Signal Drop Android 10
  1. kft180
    Donut Nov 14, 2019
    kft180 , Nov 14, 2019 :
    Hi would you mind being alittle more specific how to reset your network settings? I am facing the same issues and is veryy frustrating. Thank you
  2. Qmaula
    Donut Dec 10, 2019
    Qmaula , Dec 10, 2019 :
    Hi, I'm also interested in doing a network reset... Could you explain how to do it?
  3. Qmaula
    Donut Dec 10, 2019
    I did reset network settings but the issue remains. Any idea on how to report this to oneplus?
  4. Dronie_V
    Cupcake Dec 26, 2019
    Dronie_V , Dec 26, 2019 :
    Hello!
    I've had the same issue.
    Managed to fix it by going to work profile settings and activating network usage there.
  5. Qmaula
    Donut Dec 27, 2019
  6. igsigs
    Cupcake Dec 28, 2019
    igsigs , Dec 28, 2019 :
    I only see "Work profile" and "Contact search" under work profile settings. Essentially the ability to turn those on or off. Nothing about network settings. Could you elaborate on how you did it, as this issue is definitely related to having a work profile enabled.
    Thanks
    Qmaula likes this.
  7. aellerton
    Cupcake Jan 7, 2020
    aellerton , Jan 7, 2020 :
    I have the same problem - found this thread after much frustrating searching... Having Work profile activated on my 7T drops all network connections as soon as any app calls the location service.
    Only workaround I have found is to turn off the Work profile when I need location (using google maps or any app that relies on it)... Would be great to hear if OP are aware of this, or if anyone has a better fix
    Qmaula likes this.
  8. Lorenz_092
    Cupcake Jan 14, 2020 at 8:16 AM
    Lorenz_092 , via OnePlus 7T Pro , Jan 14, 2020 at 8:16 AM :
    Guys, this is a real problem.
    I'm in the same situation, and also with the latest update the situation is the same.
    OnePlus please consider this problem!
    Can we contact someone from the forum?
    losing network signal shouldn't be acceptable in 2020
    Qmaula likes this.
  9. LorenzoSar_
    Donut Jan 14, 2020 at 8:51 PM
  10. Kris Larson
    Cupcake Jan 19, 2020 at 12:34 AM
    Kris Larson , Jan 19, 2020 at 12:34 AM :
    Same issue on my 7 Pro on Android10.03 I consistently lose Wi-Fi connection and LTE . I reset my Wi-Fi Bluetooth and data connections new SIM card and I also did a complete reset reboot nothing seems to work. My phone is near useless .
