3
Network Signal Problem in Android Pie
  1. varungener Donut Sep 28, 2018
    varungener, Sep 28, 2018 :
    After yesterday's update to Android Pie I noticed one thing that is sim signals are going again and again randomly. Its a sort of restarting of sim cards. Don't know whether its a bug or something else.
  2. _Khalid Gingerbread Sep 28, 2018
    _Khalid, Sep 28, 2018 :
    first of all clear cache and wipe data. Then try re-inserting SIM card. if you have dual sim try to use one first and see if it works fine. if the issue still persist, check with an another handset or with another sim in OP6. else sent your feedback along with the network logs to OnePlus team.
    https://forums.oneplus.net/feedback/
  3. varungener Donut Sep 28, 2018
    It means problem is with my OP6. I will do the same. Thnx Sir for helping me out.
  4. harinder bhullar Cupcake Sep 28, 2018
  5. varungener Donut Sep 28, 2018
    Could you please elaborate in detail ?
  6. harinder bhullar Cupcake Sep 28, 2018
    harinder bhullar, Sep 28, 2018 :
    sim turning on and off continuously i can see happening it in sim settings
  7. varungener Donut Sep 28, 2018
    Exactly same is happening with me.
  8. Y1538110228948 Cupcake Sep 28, 2018
    Y1538110228948, Sep 28, 2018 :
    I'm having the same issues. After installing Android Pie, my phone acts like it has no service. I can't send photos, and it struggles to send texts.
  9. F_Bishwajit_Saha_xQJU Donut Sep 28, 2018
  10. varungener Donut Sep 28, 2018
    vaviprakas likes this.
  11. vaviprakas Eclair Sep 28, 2018
    vaviprakas, Sep 28, 2018 :
    yes same for me also I use 2 sim one Airtel and Jio. but Airtel is always problem... already I used open beta3 but it is good today I update stable version problem comes.. problem is some one call after call end network is not available again I go and search manually network
  12. HermioneChong Cupcake Sep 28, 2018
    HermioneChong, Sep 28, 2018 :
    same here, my signal no longer reaches 4G, it's only showing H+ now and it constantly shows no internet connection when I'm using my phone ever since the update yesterday. anyone know how to fix this or do we have to wait for another update?
    edit: I was having trouble posting this comment with the network problem as we speak!
  13. HermioneChong Cupcake Oct 2, 2018
    Y1538110228948 likes this.
  14. F_Bishwajit_Saha_xQJU Donut Oct 7, 2018
    F_Bishwajit_Saha_xQJU, Oct 7, 2018 :
    I reported a bug to oneplus team on 29th sept. they asked for logs from the device which I passed on to them. after they received the logs, they have stopped all sorts of communication. I have been trying to get response from from them but not output.
    atleast they can acknowledge that they will provide a fix in the next update.
    it has been a couple of weeks now and my regular calls from home and work has been hampered like hell.
    Team oneplus, please let us know the update.
    harinder bhullar and varungener like this.
  15. harinder bhullar Cupcake Oct 18, 2018
  16. fshipai Donut Oct 18, 2018
    fshipai, Oct 18, 2018 :
    It to happened with me after the update on my new OnePlus 6 phone within 24 hours and after resetting the phone the problem was solved
  17. deangilvin Jelly Bean Oct 18, 2018
    Kytharsis likes this.
  18. mo3011 Cupcake Mar 6, 2019
    mo3011, Mar 6, 2019 :
    same issue here since the transfer from Oreo to Pie, i guess there is no other option than downgrading to Oreo...
    Update: after downgrading back to oreo 8.1 i got the same symptoms again. Lost connectivity during a call.
    Connection to the network come and go.
    My guess is that it's an hardware issue.
  19. agower Cupcake Jun 23, 2019
    agower, Jun 23, 2019 :
    I upgraded to Pie and had the same thing. No signal. Downgraded to Oreo and it fixed it. Waited six months and installed the latest update and signal was lost. So had to downgrade again. Again this fixed it. I've sent dozens of tweets to OnePlus but they only respond to things that might result in a sale or easy fixes. They haven't replied anything I've sent. They don't give a toss. Cheap phone = no support, I suppose. Won't ever buy another OnePlus, nor recommend them.
  20. Rdv17 Cupcake Jul 13, 2019
    Rdv17, Jul 13, 2019 :
    Hello guys,
    I received yesterday my new OP7pro.
    After starting the phone, everything looked good until I placed the SIM Cards. When I inserted them, phone detected them (which means no bad placement) and asked for PINs. After PINs inserted, phone started normally but with a serious issue:
    - No network signal
    Both cards don't have any signal. I can ensure that cards has both less them one year and yesterday were working normally in my previous phone.
    Any tips to solve this problem? Can the phone be region locked?
    Thank you
