4
Network speed
  1. gowtham46
    Eclair Nov 10, 2018
    gowtham46 , Nov 10, 2018 :
    Network speed now showing up in status bar, it's shows only in the notifications bar if I swipe down. please help me to fix the network speed on the status bar near the network sign.
  2. G_PRASANTH_GUTTIKONDA_ts
    Donut Nov 10, 2018
    gowtham46 likes this.
  3. Sandy_b94
    Eclair Nov 10, 2018
  4. Praks92
    Eclair Nov 10, 2018
  5. gowtham46
    Eclair Nov 10, 2018
    how would you change the size please guide
  6. Sandy_b94
    Eclair Nov 10, 2018
    Sandy_b94 , Nov 10, 2018 :
    setting->display->display size->small
  7. gowtham46
    Eclair Nov 10, 2018
    every thing gets small if I do that. I could barely see the letters on display
  8. Desejmon
    Ice Cream Sandwich Nov 10, 2018
    Desejmon , Nov 10, 2018 :
    What you expected to happen?
    xnutzii likes this.
  9. xnutzii
    Lollipop Nov 10, 2018
    xnutzii , Nov 10, 2018 :
    obviously?!?! what the hell did you expect?
    Desejmon likes this.
  10. gowtham46
    Eclair Nov 11, 2018
    gowtham46 , Nov 11, 2018 :
    I just wanted to fix the data speed on the status bar which isn't showing up even when I turn it on but visible when I pull the notification bar
  11. gowtham46
    Eclair Nov 11, 2018
    Is this a joke or what. please check my post, I didn't wanted to smaller all the text which is available on the screen. I just wanted to fix the network speed right up there in status bar.
    BJOHEI likes this.
  12. gowtham46
    Eclair Nov 11, 2018
  13. root_master
    Ice Cream Sandwich Nov 11, 2018
    root_master , Nov 11, 2018 :
    due to notch there is not enough space. if you want network speed so badly then disable other status bar icons. common sense man.
  14. ykathi
    Cupcake Nov 11, 2018
    ykathi , Nov 11, 2018 :
    I have selected "display network speed" option however it is not visible in status bar.
  15. IRONIXS
    IRONIXS , Nov 11, 2018 :
    Hai, you can't display both battery percentage and network speed at the same time. you have select any one, because the space is very short between the camera drop. you don't need to reduce your display size.
    gowtham46, BJOHEI and ykathi like this.
  16. Irfanmd21
    Gingerbread Nov 11, 2018
  17. Irfanmd21
  18. Irfanmd21
  19. Anas Hasanain
    Cupcake Dec 20, 2018
