Never found solution
  1. theshinybeast
    Marshmallow Oct 2, 2016
    theshinybeast , Oct 2, 2016 :
    extraordinary
    #41
    Ceasedd likes this.
  2. nirmoyal10
    Gingerbread Oct 2, 2016
    nirmoyal10 , Oct 2, 2016 :
    about 20% and above of gps
    so install the xpsoed?
    #42
  3. nirmoyal10
    which rom u advice to flash?
    and banks gapps?
    #43
  4. theshinybeast
    #44
  5. se7enlyn
    Ice Cream Sandwich Oct 3, 2016
    se7enlyn , Oct 3, 2016 :
    try fastboot flash COS
    or
    candysix with opengapps
    #45
  6. se7enlyn
    GPS shows 20% drain? and you did not use any navigation apps during that time? what kind of apps do you usually install?
    #46
  7. nirmoyal10
    Gingerbread Oct 3, 2016
    nirmoyal10 , Oct 3, 2016 :
    Whatsup facebook instegram , shazam , youtube, poweramp, twich , and sometimes waze
    those are the most apps i use .
    #47
    se7enlyn likes this.
  8. nirmoyal10
    Gingerbread Oct 6, 2016
    nirmoyal10 , Oct 6, 2016 :
    i will test banks and opengapps with 10/9 update and will let u know.
    i will install whatsapp only
    so far this is what i am talking about:
    and this problem is since forever was in LP roms and now in MM
    i dont remember if i had drain of gps in KK
    #48
  9. nirmoyal10
    Gingerbread Oct 7, 2016
    nirmoyal10 , Oct 7, 2016 :
    Did full wipe and flash candysix 3.2s official
    with banks gapps
    installed whatsapp and anysoftkeybord only.
    so far its the same with 7 hours mobile radio active.
    should i try full wipe and flash open gapps instead?
    #49
  10. se7enlyn
    Ice Cream Sandwich Oct 7, 2016
    se7enlyn , Oct 7, 2016 :
    Go ahead and try
    #50
    jstepa likes this.
  11. secretkloud
    secretkloud , Oct 7, 2016 :
    OK. I don't know if you know this but sometimes, depending on where you live and your network, you'll get play services drain for a few days AFTER you flash a new ROM. There's a lot of updates for thee phone to receive and plenty of data to add to cache, especially if you have GPS on and WiFi scanning on. Play Services will prevent deep sleep and run your battery down if you leave Waze open in the background sometimes and also if Google Now is enabled. You can set Play Services to optimize all you want but it won't happen if you keep flashing ROMs and have an iffy network.
    I suggest the following
    • STOP FLASHING ROMs. Pick one and stick with it for at least two weeks before you consider changing. I use SultanXDA's MM ROM and I'm happy with it. I also use open nano GApps and that's fine too. You can use Banks if you want, Just STOP FLASHING DIFFERENT ROMs.
    • Install all the apps you use and wait at least two days before complaining. Play services does a lot of things in the background and most of them aren't battery friendly. It will need a while to settle down, and more apps installed (especially GPS requiring apps like Waze, Instagram and Facebook) equals longer settling time.
    • Consider using permissions to deny GPS access to most apps installed on your phone. If you use Waze or Maps etc. often you should leave GPS on, otherwise you might want to turn off location settings completely (including the WiFi scanning setting).
    • Finally when you're done using GPS or WiFi Hotspot and whenever you want to go to sleep at night you should restart your phone. It's easier for Doze to kick in that way, and Play Services are less of a bother
    Oh, and only install apps you absolutely need. Apps that continuously ping home will KEEP MOBILE RADIO ACTIVE, especially if they don't do it at the same time, which they won't do if DOZE never kicks in, which won't happen if background apps keep pinging home. So do the following:
    • Make sure you have TWRP 3.0.2 official
    • Clean flash SultanXDA's ROM. You can get it from here
    • Flash Open GApps or Banks GApps nano
    • Boot your phone and log in with your gmail account
    • Reboot to TWRP and Flash SuperSU from Chainfire if you're interested
    • Flash Xposed after this (if you're interested)
    • Flash A.R.I.S.E. sound if you want (for better sound)
    • Reboot
    • If you flashed Xposed you may want to first install Amplify and Greenify, your choice. If you install these reboot again
    • Install all your frequently used apps and set up all accounts. Make sure everything is set up the way you like. Reboot whenever you think is necessary.
    • WAIT A FEW DAYS BEFORE COMPLAINING. Wait at least three or four days. The first day will definitely be rough as Play Services builds caches
    • Don't forget to restart your phone every night
    • Report back on Monday with progress report...
    Whew!!!
    #51
  12. se7enlyn
    Good advice!
    May i add, don't install FB, just use Chrome for it.
    #52
  13. nirmoyal10
    hey man i am appriciate your comment
    sadly i have done it already and i was with same roms more than 2 month.
    each rom had high drain and i kept closing Waze and gps.
    I cant optimizing Google play sevice but someone above said that there is a gapps that can do so.
    I have tried alot of roms more than 20 including LP/MM roms.
    I let it sittle but same as always results so now i think i should get alterantive solution like optimizing it
    #53
  14. dhairyarc1
  15. nirmoyal10
    Gingerbread Oct 8, 2016
    #55
  16. dhairyarc1
    Ice Cream Sandwich Oct 8, 2016
    dhairyarc1 , Oct 8, 2016 :
    well try it one :) and let me known then believe me
    #56
  17. nirmoyal10
    nirmoyal10 , Oct 8, 2016 :
    ok i wil try it
    #57
  18. dhairyarc1
    #58
  19. okak24
    #59
    Prinze Martin and nirmoyal10 like this.
  20. okak24
    #60
    nirmoyal10 likes this.
