19
New System Update for COS12 : YNG1TAS17L
  1. Stupendousman
    Ice Cream Sandwich Apr 23, 2015
    Stupendousman , Apr 23, 2015 :
    Can´t install it with TWRP...
    And if i click on the OTA Message, the One boots into TWRP and nothing happens...
    Anyone an idea?
    #81
    muza_1 likes this.
  2. ubizmo
    Gingerbread Apr 23, 2015
    ubizmo , Apr 23, 2015 :
    Thank you, I'll do that. But is the update still sitting in storage on the phone somewhere?
    #82
  3. Gflash890
    Cupcake Apr 23, 2015
    Gflash890 , Apr 23, 2015 :
    I installed the Update, but my Battery is still draining.... I've a Battery time from 9 to 5 and the most of the time the phone is in standby.... Please fix this bug before you push new Stuff...
    #83
  4. aziz.yarahmadi
    Eclair Apr 23, 2015
    aziz.yarahmadi , Apr 23, 2015 :
    Cant agree more dude!
    #84
  5. Paulquito21
    Honeycomb Apr 23, 2015
    Paulquito21 , Apr 23, 2015 :
    I flahed the official COS12 last week, nonrooted.. Would it do anything different if I flash this? Its the same build number and size
    #85
  6. ubizmo
    You have to download it using the link in this thread and then use TWRP to install it. The direct OTA route won't work.
    What I still don't know is whether the OTA is sitting somewhere in storage taking up half a GB.
    #86
    agychan and cubes123 like this.
  7. jferraz
    jferraz , Apr 23, 2015 :
    This is the kind of communication i'd also expect from Oneplus. Hopefully they can learn from their mistakes and learn what user support is about.
    #87
    vdrod and Wadesauce like this.
  8. Stupendousman
    I did it this way.. but as i said... Can´t install it with TWRP...
    Get an error: Error executing updater binary in zip...
    #88
  9. abepaniagua
    Froyo Apr 23, 2015
    abepaniagua , Apr 23, 2015 :
    I get a fail message too. I'm on the first update and try the OTA route and then the flash zip one. None worked.
    #89
  10. ubizmo
    Sorry, I don't know what to suggest. The installation using TWRP went smoothly for me. Had you made any other modifications to the system before trying? My only mod (besides rooting) was a modified gps.conf file.
    #90
  11. Paulquito21
    after the update from COS12 build last week. I updated it manually - non rooted.
    Now I dont get errors when I switch to Guest profile..
    OK oneplus is here but its GARBAGE
    #91
    ahighfield likes this.
  12. Garner
    Donut Apr 23, 2015
    Garner , Apr 23, 2015 :
    I'm still running CM11S, colleague of mine has flashed to to the new OTA.
    His battery is draining triple speed compared to mine. 100% to 50% in 3hrs.
    I'm still on, as of 14:23pm GMT now from 6am GMT this morning, 82%.
    Seems CM12x has not addressed battery drain.
    #92
    Gflash890 likes this.
  13. kubiksrubiks
    kubiksrubiks , Apr 23, 2015 :
    Agree. The wifi is till showing as awake even if it's turned off. Damn you, Cyanogen.
    #93
  14. ardicli2000
    ardicli2000 , Apr 23, 2015 :
    That's the Steve Kondik itself. Woow.
    I hope you read our bugs/whishlist threads as well. There are very serious reports in those threads.
    I know you have a JIRA system which is a lot more technical and maybe helpful to you, but as you said once, this is not a Custom Rom anymore. This is a whole OS. And Cyanogen is a brand now. So it will be good to pay attention what customers say in the forums.
    Regards.
    #94
    genab.de likes this.
  15. Stupendousman
    ok..
    Just Root and changed DPI to 380... Nothing more...
    @Garner : sorry but i have no Battery Drain on CM12.. maybe there is a google feature hanging... But Battery Life is equal for me between Cm12 and CM11S... 4-6Hours Dot are normal...
    #95
  16. indiangamer007
    Jelly Bean Apr 23, 2015
    #96
    abepaniagua likes this.
  17. FrayAdjacent
    Eclair Apr 23, 2015
    FrayAdjacent , Apr 23, 2015 :
    Good news is I can connect to my Moto360 again. I'll have to see tonight when I go to work if the battery drains like crap again. Hopefully it's back to normal.
    #97
  18. Vivian Lobo
    Vivian Lobo , Apr 23, 2015 :
    I hate sideloading. Hoping the roll out reaches my phone soon. Been waiting for the lollipop goodness. However, now I think I am waiting for the 5.1 version of it. Too confused... As 5.0 has problems reported.
    #98
  19. WJvdR
    Froyo Apr 23, 2015
    WJvdR , Apr 23, 2015 :
    Can you still use OK Google??? Or has that been dropped in favour of Ok Oneplus?
    #99
  20. Rahul86
