3
[NEW UPDATED] CyanogenOS 13.1.2-ZNH2KAS3P0-bacon
  1. akvijendra
    Honeycomb Aug 25, 2016
    akvijendra , Aug 25, 2016 :
    Duh..was hoping this was the much expected VoLTE update. Unacceptable expectations I guess!
    #41
  2. ujangodong
    Eclair Aug 25, 2016
    #42
  3. arjanvlek
    #43
    CasperTFG and rwmchan like this.
  4. TomazO
    Gingerbread Aug 25, 2016
    #44
  5. rwmchan
    Jelly Bean Aug 25, 2016
    #45
  6. tttl
    Ice Cream Sandwich Aug 25, 2016
    #46
    evon likes this.
  7. beeflon
    Donut Aug 25, 2016
    beeflon , Aug 25, 2016 :
    Yes, because cm user made too many server request.
    #47
  8. alakyr
    Froyo Aug 25, 2016
    alakyr , Aug 25, 2016 :
    guys if I fully unroot the phone and then I flash the stock cos recovery the ota will work or the system is "compromised"?
    #48
  9. nickelodeon
    nickelodeon , Aug 25, 2016 :
    You have to unroot the phone, there is an option on supersu app
    Flash stock system partition of ZNH2KAS2X1 with fastboot
    Flasth stock recovery
    and it might work
    #49
  10. little_alien
    Cupcake Aug 25, 2016
    little_alien , Aug 25, 2016 :
    Update installed last night on GF Phone. very warm after install, Crashing and freezing not even hard reboot works. have to wait for it to do it itself. meh...
    #50
  11. KarolN
    KarolN , Aug 25, 2016 :
    hi there, i made the update to P0-bacon but now he cant find my sim. i am on stock and have never made any specials. tried to reboot, wipe cache, factory reset but still not detected. any solution for that? could not find anything for stock users.
    thanks!
    #51
  12. alakyr
    Froyo Aug 25, 2016
    yeah I know...thank you man ;)
    #52
  13. Jazzy63
    Eclair Aug 25, 2016
    Jazzy63 , Aug 25, 2016 :
    I had the same thing, weird thing is, that after about 4 freezes crashes and reboots, it no longer freezes and crashes. So give it some time i guess.
    #53
    little_alien likes this.
  14. harry_db
    harry_db , Aug 25, 2016 :
    Does the patch give a fix for the weak LTE signal? As the last 2 patches on COS made my phone got almost no signal on LTE, afterward i switch to O2 OS while waiting this to be fixed.
    #54
  15. megatomic
    megatomic , Aug 25, 2016 :
    The only glitch I'm seeing is that using Google Now Launcher with FX File Explorer I can't apply wallpapers, I get an error saying that it couldn't load the wallpaper. If I apply using the built in File Explorer there is no problem. I didn't experience this problem whilst running Sultanxda CM13 ROM. No big deal really but it annoys me.
    #55
  16. CrAcKeZ
    CrAcKeZ , Aug 25, 2016 :
    Did the fix the "broken" charging led when the phone is turned off or it's still broken since COS12 ?
    #56
  17. xasx
    xasx , Aug 25, 2016 :
    Not really.
    To be more precise: you will not lose anything that cannot be built by the OS afterwards and automatically.
    Basically it has a look at your apps and builds up this cache with pre-compiled native binaries in order to start the apps faster.
    #57
  18. CrAcKeZ
    Currently on 3.10.40 kernel, check XDA community lighting kernel v5 ..we'll get CM14 for sure, just not COS14
    #58
    CasperTFG likes this.
  19. thehogester
    thehogester , Aug 25, 2016 :
    Is it? I've never had issues before, but following this update my battery is draining in front of my eyes. It's also taking forever to charge. What causes it, if its normal?
    #59
  20. megatomic
    I fixed it. For some reason the Google App didn't have the Storage permission. Once I enabled it the problem I had disappeared. Now no problems are to be found on my 2+ year old OPO (that I'm aware of).
    #60
