3
[NEW UPDATED] CyanogenOS 13.1.2-ZNH2KAS3P0-bacon
  1. kukannan
    Cupcake Aug 29, 2016
    kukannan , Aug 29, 2016 :
    Upgraded to 13.1.2 version and not able to connect to mobile data. Connection over wi-fi is working fine. Anyone else facing this issue?
    joseqzd likes this.
  2. kukannan
    Toggling the airplane mode, bluetooth settings and rebooting got it working. Pls ignore the previous post.
  3. rwmchan
    Jelly Bean Aug 30, 2016
    rwmchan , Aug 30, 2016 :
    After updating to ZNH2KAS3P0, it was found that Google Now is not working properly. When launching Google Now or Now on Tap, the error message "Google Now can't be reached at the moment" will be shown.
  4. CasperTFG
    KitKat Aug 30, 2016
    CasperTFG , Aug 30, 2016 :
    Color me impressed. I turned off AudioFX while my OPO was connect to my after market car sterio (Sony) via Bluetooth and then I turned it back on and I could tell the difference in doing so. The app/functionality responded to on/off. In the past I would have avoided turning off AudioFX for fear that it wouldn't go back on requiring a reboot.
  5. TForesto
    Gingerbread Aug 31, 2016
    TForesto , Aug 31, 2016 :
    Google now, has not worked on my device since the last three updates. I don't know why.
  6. rwmchan
    Jelly Bean Aug 31, 2016
    rwmchan , Aug 31, 2016 :
    well, i haven't checked seriously whether google now is working since the last 3 updates. at least, there was no error message "Google Now can't be reached at the moment" until the latest update. anyway, i have reported to jira yesterday.
  7. srihari180
    Cupcake Aug 31, 2016
    srihari180 , Aug 31, 2016 :
    Updated to ZNH2KAS3P0. Root access option is missing in developer options. It was missing in previous update too. Does rooting through superSU is the only option now?
  8. nickelodeon
    Honeycomb Aug 31, 2016
    nickelodeon , Aug 31, 2016 :
    Root access were never available under developer options for Cyanogen OS, you're confusing Cyanogen OS with Cyanogenmod.
  9. dhairyarc1
    Ice Cream Sandwich Sep 4, 2016
  10. Messisan321
    Cupcake Sep 4, 2016
    Messisan321 , Sep 4, 2016 :
    Am i really the only one who hasnt gotten the new CM13 update yet?, im still running CM12 on -android 5.1.1
  11. play1962
    Cupcake Sep 5, 2016
    play1962 , Sep 5, 2016 :
    I was getting horrible battery life so I downgraded back toZNH2KAS2X1now battery life is back ;)
  12. gringoboy
    Lollipop Sep 5, 2016
    gringoboy , Sep 5, 2016 :
    What does it say in current OS in about phone?
  13. NYD
    Cupcake Sep 5, 2016
    NYD , Sep 5, 2016 :
    Can I flash ZNH2KAS3P0 on COS13.0 ZNH0EA2JK? I am currently on rooted COS13.0 ZNH0EA2JK.
  14. gringoboy
    I'd be tempted to wipe first if you're missing out 3 versions. You can get them here. Use the signed flashable zips only.
  15. NYD
    Cupcake Sep 5, 2016
    NYD , Sep 5, 2016 :
    That means, should I first flash the between 3 updates?
  16. PaulF8080
    Gingerbread Sep 5, 2016
    PaulF8080 , Sep 5, 2016 :
    Do you understand what incremental means? Sometimes I wonder if people understand each increment could be changing different files because incremental means only parts are changed.
  17. najericam
    Cupcake Sep 5, 2016
    najericam , Sep 5, 2016 :
    Can someone help me? I havr issue with weather widget. A few updates ago, I needed to download weather provider from play Store but now I can't do that, it say that it's not supported. If I download it and install manually, not working also. So any way to get back original weather on cLock widget?! And yes, I try factory reset, even flash phone again whit latest version...
  18. gringoboy
    Afaik, that weather widget is no longer available. Yahoo stopped it I think. I'm in the UK, so BBC is good for me, but I've heard many say that Chronus is a good substitute.
  19. dam76
    Eclair Sep 5, 2016
    dam76 , Sep 5, 2016 :
    yes, but I'm afraid that without driver support the phone performance will be seriously penalized. You get the latest fuctions and security updates, but the phone is considerably slower...
  20. johncel.espares
    Froyo Sep 5, 2016
