94
Next generation of OPPO's VOOC Flash charging is here, says SAFETY first !
  1. CosmicPaladin
    Jelly Bean Writers' Club Jul 28, 2021
    CosmicPaladin , Jul 28, 2021 :
    OPPO has been at the forefront when it comes to battery charging technology, in the form of VOOC, the in-house flash charging. This has been leveraged well by OPPO's cousins such as RealMe and OnePlus in different names and has stood out as of the key features customers love.
    VOOC went on from 18w to 30w to 65w to 120w charging speeds which is phenomenal. But there has always been one concern in the minds of not just tech enthusiasts but the users too - how safe are these flash charging speeds? How do they affect the phones in the long term? How will the increasing heat generation be handled? Now OPPO wants to put these concerns to rest.
    PC: OPPO
    Earlier this week, OPPO in its "What's Next For Flash Charging" event and made some announcements of what they've done to address the safety concerns, with the following:
    1. Fuse with lower impedance - In cases where there is an overload/surge of electric current, the new lower resistance fuse will blow and isolate the battery from this supply
    2. Gallium Nitride (GaN) Switches - For the first time, OPPO will be using GaN Switches in its smartphones, which not only function as a traditional MOSFET but also double up as low impedance and high voltage units for heat dissipation. This also leads to battery life improvements
    3. Internal series bi-cell design - Bi-cell design has been there for a while, but a new approach of combining the dual battery cells in the same structure allows for around a 5% increase in battery capacity for the same battery size. In addition, it also helps reduce heat generation
    4. Battery Safety Generation Chip - An AI-based chip will detect if the battery is damaged, by recognizing real-time voltage drops across various scenarios and alert the users via the OS and propose actions to be taken
    5. Composite Current Collector - The all-new composite current collector consists of a composite material sandwiched between aluminum layers as opposed to aluminum-only in normal batteries. This is further reinforced with a 5-layer protective material that shields it from short-circuiting. Lab tests have shown a 100% success rate when the battery was put through puncture and collision cycles.
    In addition to the above, there are other benefits such as maintaining a battery health of 80% even after 1500 cycles, cherry-picking scenarios to increase charging speeds by as much as 20%, strike a better balance between charging speeds and handling temperatures
    PC: OPPO
    With around 3000 patents and support for over 30 devices, VOOC Flash Charge's important step towards "Safety" focus is a welcome move for a potential user set of 195 Million worldwide, allowing people to charge any device, anytime, anywhere. It's very heartening to see OPPO focusing on safety aspects in addition to the crazy charging speeds. Hopefully, this becomes a norm pan-industry!
    We always know OnePlus leverages OPPO's R&D. Do you think picking up these advancements onto WARP charge for OnePlus would give it an additional edge that you'd look forward to, now that it brings in safety aspects too? Drop your thoughts below!
    Ref: OPPO
  2. Overzee
    Junior Moderator, The Showcase Reviewer Junior Moderator Jul 28, 2021
    Overzee , Jul 28, 2021 :
    When VOOC flash charging/WarpCharging can be done more safely, that's always good IMO.
    So the power supply will need to be replaced and/or serviced I guess?
    That's great, a built-in battery check running in the background. I like this!
    This technique has proven itself, so this is great!
  3. AlienEye
    OnePlus Accessory Tester Jul 28, 2021
  4. kushal_gowda_a
    Ice Cream Sandwich Jul 28, 2021
  5. RamiroNoguer
    Donut Jul 28, 2021
    northbay5566 and K1627752285654 like this.
  6. Jayshah17
    Gingerbread Jul 28, 2021
  7. AAA_Freddo_Addle
    K1627752285654 likes this.
  8. Aditya_4
    The Lab Reviewer - OnePlus Nord 2 Jul 28, 2021
    RamiroNoguer and K1627752285654 like this.
  9. SRD.
    The Lab Reviewer - OnePlus 9RT 5G Jul 28, 2021
    SRD. , Jul 28, 2021 :
    Sounds like an official thread @CosmicPaladin 😜.
    Graphene is going to be the next big thing for battery technology.
    Heat dissipation & absorption are the few major challenges.
  10. Z1612187578731
  11. NoviceAide
    Honeycomb Jul 28, 2021
    NoviceAide , via OnePlus 8T , Jul 28, 2021 :
    Ofcourse. It would spice up OnePlus' offerings even more. I was already amused by the speed of Warp 65. Just imagine how an even faster charging would fare.
  12. C1624788922607
  13. itsakash
  14. pkg3107
    Jelly Bean Jul 28, 2021
    pkg3107 , Jul 28, 2021 :
    120 W is crazy fast. The thing I would like to know more about is the overall battery life difference between the 65W and 120W. I find 65W to be more than sufficient, but if I am getting 120 without any long time damage to battery, it seems a great change to me...
  15. 5l4rtysCell
    5l4rtysCell , via OnePlus 9 Pro , Jul 28, 2021 :
    Anything that increases battery life and charging speed is definitely welcome. I think we've all come across the battery heating up during it's charge. To be honest, I always have a nagging in the back of my mind that I'm damaging my phone with all this fast charging malarkey. So this news is great.
  16. AdrianoS USA
    Gingerbread Jul 29, 2021
  17. AKP_OPUSER
    Froyo Jul 29, 2021
