Next PC build
  1. d1y4b
    Froyo Mar 21, 2015
    d1y4b , Mar 21, 2015 :
    Hey, I'm going to build a gaming PC pretty soon. I have about £200 which translates to $300 USD. This is going to be my first actual PC build from scratch as I have upgraded PC parts in the past.
    Here is what I have:
    1 -Zalman t5 case
    2 -1tb hard drive
    3 -CD drive
    4 -750w modular xilence power supply
    5 - windows 7
    These are from my old custom build PC and I'm pretty sure they can be used in my new build.
    What I need:
    1 - CPU
    2 - motherboard
    3- ram
    I can buy the graphic card later and I have about £100 for the graphics and left overs from the CPU money. Also I'm not going to be doing any over clocking but I have a Asus square EVO cooler for LGA 775/am2+ and I'm just wondering if it could be reused with the newer sockets
    abhishek kurup likes this.
  2. vmk2310
    Jelly Bean Mar 21, 2015
    vmk2310 , Mar 21, 2015 :
    Can you try putting it into PcPartPicker please? It helps organize things too.
    rez1_k and erzengelsachiel like this.
  3. d1y4b
    Froyo Mar 21, 2015
    Yea sure
  4. vmk2310
    Okay I read that all wrong ignore that, well what socket is your motherboard?
  5. d1y4b
    Froyo Mar 21, 2015
    vmk2310 likes this.
  6. d1y4b
    Froyo Mar 22, 2015
    vmk2310 likes this.
  7. d1y4b
    Froyo Mar 22, 2015
    d1y4b , Mar 22, 2015 :
    I'm looking for a good motherboard, ram and a CPU under £200/$300
    vmk2310 likes this.
  8. vmk2310
    Jelly Bean Mar 22, 2015
    vmk2310 , Mar 22, 2015 :
    Do you prefer Intel or AMD for CPU's?
  9. d1y4b
    Froyo Mar 22, 2015
    Well to be honest I dont have a preference in CPU as brand doesn't matter to me
    vmk2310 likes this.
  10. Chugz
    Ice Cream Sandwich Mar 22, 2015
    d1y4b and vmk2310 like this.
  11. vmk2310
  12. vmk2310
  13. vmk2310
    Chugz and d1y4b like this.
  14. d1y4b
    Froyo Mar 22, 2015
    Thx guys I would go with the MSI gaming motherboard and also is there any Intel builds under this Price
    vmk2310 likes this.
  15. Slyther1
  16. d1y4b
    Froyo Mar 22, 2015
    The case is a micro atx case, I'm just wondering I can get a haswell i5 with a really cheap mobo with 4gb ram under £200/$300. Is this worth it?
  17. Slyther1
    Slyther1 , Mar 22, 2015 :
    don't go too cheap on the mobo. i5 is good, but you should try and get its name and run a comparison on https://www.cpubenchmark.net/
  18. beyondthebat
    Donut Mar 22, 2015
    beyondthebat , Mar 22, 2015 :
    Honestly I dont think the cpu upgrade is worth it. the i5 by itself costs about 150-200. AMD does a good job.
    erzengelsachiel, Chugz and d1y4b like this.
  19. beyondthebat
    Donut Mar 22, 2015
  20. d1y4b
    Froyo Mar 22, 2015
