NFC does not need fingerprint or face unlock
  1. BrutalisCZ Cupcake Jun 25, 2019
    BrutalisCZ, Jun 25, 2019 :
    Why? Every other phone need authorization for NFC.
    You can just use it from lockscreen..
  2. stark2991_PL KitKat Jun 25, 2019
    stark2991_PL, Jun 25, 2019 :
    You have one of the Smart Lock options enabled.
  3. BrutalisCZ Cupcake Jun 25, 2019
    stark2991_PL
    You have one of the Smart Lock options enabled.​
    umm this is what comes up after I wrote "Smart Lock" in search - it is disabled . or should I check somewhere else?
  4. dsmonteiro Community Consultant Community Expert Jun 25, 2019
    dsmonteiro, Jun 25, 2019 :
    Authorization for what? To enable/disable NFC or to make payments with it?
  5. BrutalisCZ Cupcake Jun 25, 2019
    payments and opening doors
  6. BrutalisCZ Cupcake Jun 25, 2019
    wait so I turn on the "show Lock options" but then - where do I see the options?I have everything turned off here
  7. BrutalisCZ Cupcake Jun 25, 2019
    again - NFC only works on lock screen, it does not work on Ambient display.
    I have face Id turned off.
    When I press power button - lock screen appears.
    Without me Putin finger on display I can use NFC for paying and opening doors.
  8. stark2991_PL KitKat Jun 25, 2019
    I don't even know what settings did you show on the screenshot. I don't know this language.
    Smart Lock should be in the Settings -> Security section
  9. BrutalisCZ Cupcake Jun 25, 2019
    stark2991_PL
    yeah that's what I did - that is the white screenshot. I have everything off, except "Ok Google" in maps ( voicematch )
    1st screenshot is when you write Smart Lock in search
  10. BrutalisCZ Cupcake Jun 25, 2019
    stark2991_PL
    I have everything turned off in"smart lock settings - as you suggested as you can see in this screenshot except voicematch in google maps - that I have on.
    this is the option than gives me 1st screenshot
    where do I see "power button option"from last screenshot?this is what comes up after I search for "smart lock"
    Where do I see "lockdown option" ?
  11. BrutalisCZ Cupcake Jun 25, 2019
    btw this is what I meant by "Lockscreen" just to be clear .
    on this screen my NFC payments work without me using the finger print and while face id turned off
    btw I found what lockdown is - it's when you hold power button very long and it does not have anything to do with my problem
  12. Blue-agila Ice Cream Sandwich Jun 25, 2019
    Blue-agila, Jun 25, 2019 :
    Are you talking about payment with Gpay
  13. BrutalisCZ Cupcake Jun 25, 2019
    Blue-agila
    actually no, I am talking about payment with application from my bank, BUT I am also talking about opening doors. With simply NFC nothing else no app
  14. Blue-agila Ice Cream Sandwich Jun 25, 2019
    To my knowledge you only need to wake the phone not unlock it for NFC to work
  15. BrutalisCZ Cupcake Jun 25, 2019
    hmmm .... mkay ...
  16. Vansh99 Ice Cream Sandwich Jun 25, 2019
    Vansh99, Jun 25, 2019 :
    https://support.google.com/pay/answer/7644132?hl=en
    According to this, you don't necessarily need to unlock your phone in order to make payments (chart listed on the link).
    Oh I just noticed you're not necessarily taking about Google pay. But I'm assuming, the NFC payment relies on google's system of NFC payment so it follows the same procedure of paying without unlocking the phone just like Google pay.
  17. BrutalisCZ Cupcake Jun 26, 2019
    BrutalisCZ, Jun 26, 2019 :
    Well is there a way to make it necessary?
