NFC issue in OP6!!!
  1. Dr.divyank
    Cupcake Aug 21, 2019
    Dr.divyank , Aug 21, 2019 :
    I m not able 2 connect/ transfer via NFC. It's like whenever I touch to beam the other phone opens play store and displays item not available. Anybody else facing this issue?
  2. ngydat
    KitKat Aug 21, 2019
    ngydat , Aug 21, 2019 :
    Did you enable Android Beam ?
  3. Dr.divyank
  4. ngydat
    KitKat Aug 21, 2019
    Most of the users I dealt with in this forum were quite oblivious with this kind of thing. Hence my question
    Kytharsis likes this.
  5. Starcommander
    KitKat Aug 21, 2019
    Starcommander , Aug 21, 2019 :
    What file are you trying to share?
  6. Dr.divyank
  7. Starcommander
    KitKat Aug 21, 2019
    Whenever I connected my op3 with op6t using nfc, bluetooth would turn on and the file got transferred successfully when both parties had same application. Try sharing web page. Mostly what is happening is when you are touching both the phones the application currently running on OP6 goes to the next phone via nfc and hence google play opens. To share the files, go to share option and tap android beam
    Dr.divyank likes this.
  8. Dr.divyank
    is it necessary to pair them via Bluetooth first? coz earlier it was not an issue
  9. Starcommander
    KitKat Aug 22, 2019
    Starcommander , Aug 22, 2019 :
    No not needed. Only its necessary to tap on share via beam
