NFC not working - options grayed out
  1. lijuvj19
    Cupcake Nov 24, 2017
    lijuvj19 , Nov 24, 2017 :
    Hi all,
    I'm using Oneplus 3T running with the latest Android Oreo.
    My phones NFC is not working even if i try to turn it on from the notification toggle it won't respond and the NFC option in the settings are grayed out. I tried factory reset, but it didn't worked out. I noticed this problem recently when i was trying to use android pay. I have seen NFC turned on before but never used it. I'm not sure this happened after the Oreo update.
    Please see the screenshots attached
    dpiovani likes this.
  2. Sun90
    Starting Point Expert Nov 24, 2017
    Sun90 , Nov 24, 2017 :
    Please use a browser app to login to forum and upload the Screenshots
  3. lijuvj19
    Thanks for the quick reply.
  4. Sun90
    Umm.
    That's weird.
    NFC works fine on my op3 running beta 27.
    Perform a cache wipe in recovery mode and see
  5. lijuvj19
    Thank you..
    I did wipe cache partition from recovery, clear cache memory of NFC from apps then did a factory reset. None of them worked
  6. Sun90
    Wait for a day or two.
    Once the full ROM zip file of this build is up on OnePlus site download section , download it and do a local upgrade and see.
  7. lijuvj19
    For 3T they did uploaded the latest full rom today(11/24/2017) and i tried to update locally. Even after the local upgrade its not working.
  8. lijuvj19
  9. dpiovani
    Cupcake Dec 26, 2017
  10. lijuvj19
    lijuvj19 , Dec 26, 2017 :
    nop.. still not working
  11. ajeethr
    Cupcake Jan 13, 2018
    ajeethr , Jan 13, 2018 :
    Any update? I have the same problem, my device is a 5T though.
  12. dpiovani
  13. aoprea75
    Froyo Jan 26, 2018
    aoprea75 , Jan 26, 2018 :
    i have same problem on OP5T ... NFC toggle is inactive greyed (but enabled) ... android beam is same inactive ..
    can't disable or enable again nfc
    what to do ?
  14. C2H6O
    Eclair Nov 6, 2019
