Night Mode issue
  1. E1528389282093
    Froyo Aug 20, 2018
    E1528389282093 , Aug 20, 2018 :
    Night mode should have an option to NOT automatically adjust change color temperature based on ambient light.
    Like in iPhone, once night mode is ON, it keeps the color temperature at the same level and doesn't change it with ambient light. Is is more simpler and convenient and saves battery from unnecessary usage of ambient light sensor.
  2. TheOnlyArtz
    Eclair Aug 21, 2018
    TheOnlyArtz , Aug 21, 2018 :
    As far as I know and according to my experience, the Night Mode strength won't adjust, you need to set it in Night Mode settings.
  3. E1528389282093
    Froyo Aug 21, 2018
    E1528389282093 , Aug 21, 2018 :
    Once you set the strength, the phone continuously tries to change it according to surrounding condition.
    Max strength-in dark ;
    Low strength-in daylight.
    It's not absolute like in iPhones-where you once set the strength,it remains constant.
    xnutzii likes this.
  4. xnutzii
    Lollipop Aug 21, 2018
    xnutzii , Aug 21, 2018 :
    No, wrong. As the OP said, the phone will adjust the tone according to the ambient.
    I don't think it's possible to change it, you have to use a third-party night mode for that unfortunately. If you want to submit any feedback according to this, feel free to do so here:
