nightscape camera for front camera
  1. Avi_goud
    Cupcake May 27, 2019
    Avi_goud , May 27, 2019 :
    There is no option to front camera for nightscape mode.
    Google pixel having nightscape mode for front camera also.
    one play have to give update on this.
  2. B_Wrath
    Junior Moderator Junior Moderator May 27, 2019
    B_Wrath , May 27, 2019 :
    Install GCam mod and use it.
    Anyways, nightscape using the front facing sensor will be pathetic.
    xnutzii and otto2 like this.
  3. youbi
    Head Moderator Head Moderator May 27, 2019
    youbi , May 27, 2019 :
    Just out of curiosity, in what scenarios you would like to use that feature exactly?
  4. Avi_goud
    just for night time selfies
  5. Avi_goud
    how it will be pathetic, could you explain?
  6. B_Wrath
    The sensor isn't well equipped to capture light needed for nightsight. It will cause it to look like a painting rather than a picture.
  7. youbi
    The issue there is that the feature isn't made for taking pics to people. If you check the name, it basically says it all. That mode is meant for taking pictures to landscape at night. ;)
    "With Nightscape 2.0, cityscapes shot at night look bright and detailed. Thanks to a larger sensor with a wider dynamic range and faster processing speeds, shooting stunning night scenes simply takes a single tap."
    It's really not meant to take the type of pictures you want. For that you are probably better with just using the screen flash feature that the phone has. :)
    xnutzii, harshit.b, B_Wrath and 2 others like this.
