No 3D sound in headphones on ONE PLUS 7T
  1. Q1603291288051
    Cupcake May 14, 2021
    Q1603291288051 , May 14, 2021 :
    Anyone facing headphones issues
    Like no 3d sound
    And sound only on one side
    Tried using different headphones but still facing same issue even tried changing media connecting cable but nothing worked
    And also my mono audio option is off
    My device : ONE PLUS 7T
  2. Sam197
    Jelly Bean May 15, 2021
  3. Q1603291288051
    Cupcake May 15, 2021
    Q1603291288051 , May 15, 2021 :
    Did it but didn't worked
    Only I can hear sound on right side
    Like if I hear 3d music the left side output is very less
    And I tried this with other headphones but didn't worked
  4. Sam197
    Sam197 , via OnePlus 7T , May 15, 2021 :
    That's wierd
    Check the reset options
    You can do reset apps references
    Might help
  5. Q1603291288051
    Already did that
    And also tried resetting my whole mobile
    But didn't worked
    Any other option
    Which can help
  6. Sam197
    Reset the whole phone,do you mean factory reset?
  7. dsmonteiro
    Community Consultant Staff Member May 15, 2021
    dsmonteiro , May 15, 2021 :
    Have you tried with different earphones or try those earphones with another device?
  8. Q1603291288051
    Tried those headphones on other device and are working perfectly without any issue
  9. Q1603291288051
    Y
    Yes but it also didn't worked
