No alarm Sound via OnePlus 7 Pro
  1. O1584632461665
    Cupcake Oct 24, 2020
  2. Artemus.
    Nougat Oct 24, 2020
    Artemus. , Oct 24, 2020 :
    Remove and readd.
  3. Oreo.
    OnePlus Accessory Tester Oct 24, 2020
    Oreo. , via OnePlus 5 , Oct 24, 2020 :
    Please check if you have kept the alert slider on "Vibrate Only". Also check if Alarm Volume is sufficient to be able to listen.
    1603523006854.jpg said:
    Check your Alarm if it has any sound applied or not. If it shows "Silent" then probably no sound has been applied to your alarm.
    Also restart your device, it might resolve your issue.
  4. michelbijl
    Cupcake Oct 27, 2020
    michelbijl , Oct 27, 2020 :
    Tried all options above.
    I don't have an alarm sounding as well.
    Anyone suggestions?
    Fiddled along a bit...
    after 2 consecutive restarts, the alarm sounds again!
    Best regards
  5. Rajendra.Bhat
    Jelly Bean Oct 27, 2020
    Rajendra.Bhat , Oct 27, 2020 :
    I think 10.3.6 update fixed this issue.
    Artemus. likes this.
  6. O1584632461665
    O1584632461665 , via OnePlus 7 Pro , Oct 27, 2020 :
    Yes same
