no charging battery icon ?
  1. ouaille13320 Eclair Jan 3, 2018
    ouaille13320, Jan 3, 2018 :
    Hi, I am running oreo (the suspended update),
    And just noticed that while battery is well charging as per app ampère, battery icon shows no 'thunder' sign on it.
    Are you also facing this ? Thanks.
  2. PramodNarendra Honeycomb Jan 3, 2018
  3. PramodNarendra Honeycomb Jan 3, 2018
  4. marcusskyfall Jelly Bean Jan 3, 2018
    marcusskyfall, Jan 3, 2018 :
    It's a buggy release, you'll be better reporting this in the official thread and raising a feedback request...
  5. ouaille13320 Eclair Jan 3, 2018
    I found it is because of the cable. the strange thing is that the same cable works fine with a sony XZ.
    Other cable work with OP5, at least all is not a bug. Thanks.
  6. ouaille13320 Eclair Jan 3, 2018
  7. marcusskyfall Jelly Bean Jan 3, 2018
    Good detective work :)
  8. radeks11 Cupcake Mar 6, 2018
    radeks11, Mar 6, 2018 :
    I have similar issue and new insights. In office I'm charging via computer's USB not original charger. I have red indicator charging is OK, percentage of battery is increasing but battery icon is without flash sign. I suspect icon does not change with regular (slow) charging. It could change only with quick charging. I've just upgraded phone to Oreo and didn't quick charge yet.
  9. TombaUk Donut Oct 11, 2018
    TombaUk, Oct 11, 2018 :
    Same here, before update to oxygen 5.1.5, battery was showing lightning when charging with any cable. That was on 5.1.4
    Now I am on 5.1.5 and have only red led on when cable plugged in, and no other charging indicator.
    Charging with other 1.5A charger and good cable.
    Percentage is increasing.
    (oneplus 5)
  10. Waveform Modifier Lollipop Oct 11, 2018
    Waveform Modifier, Oct 11, 2018 :
    If you have a 1.5A charger, than it's on slow charging.
  11. TombaUk Donut Oct 11, 2018
    Tried now with 3A charger tha I use for other phones for fast charging, same there.
    As said before I went for the last update, the lightning indicator was there. After that August patch or whatever that was, gone. gone...
  12. Waveform Modifier Lollipop Oct 11, 2018
    Fast Charging on the OnePlus phone requires 4A.
  13. TombaUk Donut Oct 11, 2018
    I know, topic is not amps, but the lightning indicator is no more shown top right when charging - any charger...
    Tried now original charger.
    Percentage goes up but the lightning is no more shown when charging.
  14. Waveform Modifier Lollipop Oct 12, 2018
    Waveform Modifier, Oct 12, 2018 :
    4 amps is required to activate Fast charging on OnePlus 3/3T/5/5T/6. So. If you are only providing 3A, it's not going kick in as fast charge, period.
  15. TombaUk Donut Oct 12, 2018
    TombaUk, Oct 12, 2018 :
    The lightning icon won't show anymore, when using any charger.
  16. Waveform Modifier Lollipop Oct 12, 2018
    It will not show the lighting icon unless you use the OnePlus Fast/Dash Charger or Oppo equivalent.
  17. TombaUk Donut Oct 12, 2018
    This is not correct what you are saying.
    The flash in battery indicator was always there. I am telling yo it is bug in the latest fw.
    V1541529396559 likes this.
  18. Waveform Modifier Lollipop Oct 12, 2018
    Can you show what you mean?
  19. TombaUk Donut Oct 12, 2018
    In top right corner you have battery icon. Right? Next to clock.
    When you plug any charger there was a small lightning indicator, like on any other phone when you charge battery.
    This is no more there when charging, so unless you have led on, you don't know if you charge your phone.
    Nor on lock screen it does say that phone is being charged. That is gone as well.
  20. Waveform Modifier Lollipop Oct 12, 2018
    Ok. I would prefer a screenshot but whatever. If you think it's a bug. The community forum isn't the place to report such things.
    Report it here: http://forums.oneplus.net/feedback
