8
No horizon light for new notification
  1. ilija.dobre
    Cupcake Jul 8, 2019
    ilija.dobre , Jul 8, 2019 :
    At my experience, it should be enough to turn on 'Animator duration scale' to .5x under Developer options
    #41
    MarkoBatrac likes this.
  2. Komalpreet_Sandhu
    Cupcake Aug 4, 2019
    #42
  3. Ivan1272
    Cupcake Aug 9, 2019
    #43
  4. Ivan1272
    Cupcake Aug 9, 2019
    #44
  5. lux3320
    Cupcake Aug 25, 2019
    #45
  6. JoeTamburello77
    Eclair Sep 5, 2019
    JoeTamburello77 , Sep 5, 2019 :
    The best solution I've seen for this is an app called "Always on AMOLED | Edge Lighting"...(yes, I know, LONG name!!)
    Whenever you get a notification there is an LED ring around the whole phone, and it's extremely customizable. I'm still trying to get the settings all figured out - if anything, there are maybe too many settings, which confuses the functionality a little...but overall I'd give it a 9 out of 10.
    #46
  7. F_Zé_Martins_IZYF
    Cupcake Sep 10, 2019
    F_Zé_Martins_IZYF , Sep 10, 2019 :
    What a bad solution you just gave, it changes everything on my phone, who knows what else it did.
    I am waiting for this horizon light notification update to come out since may.
    Current status of it is that it only shows the light when I receive the notification and what I need is a constant light until I open my notification/tap the phone.
    I cant believe it has been this long for this.
    #47
  8. acwest
    Eclair Sep 12, 2019
    acwest , Sep 12, 2019 :
    The LED on the 5T did not require this to be turned on. There is a large difference in security level between allowing you to know that you have a notification (the LED) and at minimum, knowing which notification service is sending you a notification (current lowest visible setting for lock screen). I think they need more granularity on that, actually.
    #48
  9. DonDerham
    Eclair Sep 24, 2019
    DonDerham , Sep 24, 2019 :
    OnePlus 7 Pro running Oxygen OS 10.0.GM21AA. Is there any simple way to get the Horizon Light to linger longer?
    #49
  10. Villy_Reaper
    Eclair Oct 13, 2019
    Villy_Reaper , Oct 13, 2019 :
    If you use Google Assistant it won't reply if you shout "hey Google" while screen locked. Seen on OP7 PRO with Notify Buddy
    #50
  11. PrabhuN1986
    Gingerbread Oct 14, 2019
    #51
  12. spot01
    Ice Cream Sandwich Oct 14, 2019
    #52
  13. GodfatherAjay
    Cupcake Oct 15, 2019
    #53
  14. Deactivated User
    Oct 15, 2019
    #54
  15. bobbywibowo
    Cupcake Oct 16, 2019
    bobbywibowo , Oct 16, 2019 :
    I seemed to have this broken with the first Stable release of OOS 10, but it appeared to be fixed on my end after upgrading to OOS 10.0.1.
    #55
  16. Mayur_Bhuva
    #56
  17. Madhuri Sivalenka , via OnePlus 7 Pro , Oct 18, 2019 :
    This totally works! It didn't work for me till I turned on the animation scale either!
    #57
  18. Deactivated User
    Oct 18, 2019
    #58
  19. Madhuri Sivalenka , via OnePlus 7 Pro , Oct 20, 2019 :
    jasemanONE
    When you say it "works".... what do you mean? Does it light up for ALL notifications? Does it light up for more than one second...does it keep lighting up until you acknowledge the notification?
    Yup. It lights up for all important notifications. Not "other" notifications. And it lights up just once. Not more than that. Also, it doesn't keep lighting up till I acknowledge the notification. It's a one time thing. Sucks that the animations have to be turned on for it to work. I always turn animations off as that made the phone perform faster.
    #59
  20. Mayur_Bhuva
    Cupcake Oct 20, 2019
    #60
