8
No horizon light for new notification
  1. M1560335188599
    Froyo Oct 20, 2019
    M1560335188599 , Oct 20, 2019 :
    I have a OP 7 PRO with the new update, and I get absolutely no notifications, from any apps, besides Textra SMS. Horizon light doesn't work at all for anything. For instance, if i get a new email in Gmail, I get no notification, and I have to actually open Gmail to check for new messages. This never worked at all since I got the phone 4 months ago. Without this functionality, this "phone" is useless, and I really think it sucks that OP won't fix this. Something is clearly broken in their OS. Never OP again!!
    #61
  2. WraithNath
    Cupcake Nov 9, 2019
    WraithNath , Nov 9, 2019 :
    This the the correct answer, unless show all notifications is selected only SMS messages cause the horizon light to appear. Additionally show sensitive notifications needs to be enabled for some things to cause it to wake.
    #62
  3. C1538424657538
    Cupcake Feb 6, 2020
    C1538424657538 , Feb 6, 2020 :
    I have the OP 7 Pro McLaren and I'm in the exact same boat. No notifications from any other app besides Textra. I installed Plus Beat and configured it and now my horizon light is working with Textra.
    Also for anyone using make sure in notification settings go too Settings>Customize Notifications>Wake Up Screen = No
    Hope this helps someone
    #63
  4. G_Jimmie_Jones_CyLC
    Cupcake Feb 9, 2020
    G_Jimmie_Jones_CyLC , Feb 9, 2020 :
    Is there a fix for the Horizon Light now working after all the updates that came out? Just got my One Plus Pro 12GB RAM 256GB MEM and nothing... I have Android 10 Build #10.3.0.GM21AA
    Thanks you and appreciate any updates
    #64
    Patrick Rosmolen likes this.
  5. vvmilan
    Donut Feb 12, 2020
    vvmilan , Feb 12, 2020 :
    I've noticed that Horizon light isn't appearing on new notifications on my OnePlus 7 Pro for some time (10.3.0.GM21AA) and found the culprit.
    Animation duration scale (third one in Developer settings) was turned off. When I put it back on (0.5x)- Horizon light is there again!
    There's only one problem... When animation duration scale is anything than off when I go to homescreen Nova launcher has a lag of 0.5-1 second while appearing. Like it reloads the launcher every time I hit home... So I have to choose between having horizon light and laggy Nova or no horizon light and working Nova.
    #65
