36
No Incoming SMS or MMS on Verizon
  1. wotaoyin
    Donut Nov 6, 2018
    wotaoyin , Nov 6, 2018 :
    I submitted my IMEI in the Verizon App, which now recognizes my phone as "ONEPLUS 6T". However, I might have messed up my SMSC number. Can someone kindly tell me yours? To find it, dial *#*#4636#*#*, open Phone Information, scroll down to SMSC, and hit Refresh.
  2. droidrev71
    Honeycomb Nov 6, 2018
    droidrev71 , Nov 6, 2018 :
    There's a difference between an iPhone sim and Android sim card on Verizon. You need your imei number entered in Verizon's data base. A DMD form needs to be filled out by a tier 2 tech. Then it'll take a couple days for them to manually enter. Opo and other manufacturers send out the imei numbers in batches to carriers. I think opo is a step behind which is causing a headache. This should of been straightened out before purchase.
  3. S1540827483654
    Cupcake Nov 6, 2018
    S1540827483654 , Nov 6, 2018 :
    I'm also having this issue; going to call Verizon in the morning and hopefully sort this out. Setting up all of my 2 factor authentication apps has been... fun (including My Verizon).
    I'm not sure if this is related, but are any of you noticing that your phone isn't pulling voicemail information? Every other phone that I've plopped my SIM card into has automagically set this up. I think this is the first time in a few years where I've actually had to call the voicemail number.
  4. mpower4life
    Cupcake Nov 6, 2018
    mpower4life , Nov 6, 2018 :
    it's a very bizarre situation, so i called technical support and told them the issue i was having, they transferred me to to a tier 2 specialist. I told her the issue and this is what she said, she said that the device was not compatible with the network and i told her that's incorrect, the device is certified to work on verizon. I told her that the only way the device would work is if the CDMA-Less feature was turned on. She told me that isn't a feature you can just turn on because a few months back verizon retired all devices that run on CDMA making every device CDMA-Less. So idk what to do, im gonna call back tomorrow and see
  5. mpower4life
    Cupcake Nov 6, 2018
    the difference is one has nfc and one doesn't, idk if it makes a difference with connectivity
  6. mpower4life
    Cupcake Nov 6, 2018
    mine isnt recognized, i feel like when they add the device to there database it should automatically recognize what device it is.
  7. Ryankandeel
    Cupcake Nov 6, 2018
    Ryankandeel , Nov 6, 2018 :
    hey hopefully I can help you and all others. I placed my Verizon SIM in the SIM 1 Slot. after that I called *611 and the lady directed me to give my IMEI # for SIM 1 and my SIM Card #. she told me to power off the device and turn it back on and poof everything was in working order. give it a try.
    S1540827483654 and mpower4life like this.
  8. mpower4life
    Cupcake Nov 6, 2018
    thank you I'll try that tomorrow
  9. Ryankandeel
    Cupcake Nov 6, 2018
    let me know how it goes! hopefully it works for you too.
    mpower4life likes this.
  10. mpower4life
    Cupcake Nov 6, 2018
    will do thanks
  11. Ryankandeel
    Cupcake Nov 6, 2018
    one last thing if it wasn't obvious since I didn't say but it's best to be on another Verizon phone preferably in your plan for best service and communication with the tech support.
  12. mpower4life
    Cupcake Nov 6, 2018
    ok
  13. Shine L.
    OxygenOS Operations Staff Member Nov 6, 2018
    Shine L. , Nov 6, 2018 :
    Hi All,
    According to VZW's information . Users need to reactivate on www.verizonwireless.com . more detail as below:
    Scenario: If a user takes an ALREADY ACTIVE VERIZON SIM from his/her Phone and inserts it in the brand new OnePlus 6T then to ensure CDMA-Less feature is activated in their account please have user follow this instruction:
    For current VZ active customers:
    To activate/use an existing number on a new BYOD device, please ensure to log in to your account on www.verizonwireless.com> My Verizon > My Device > Activate or Switch Device and follow the instructions.
    If not working, please PM me about your device version (global version or TMO version) and device IMEI.
    Thank you so much!
    Best,Shine
  14. geoff5093
    Eclair Nov 6, 2018
    geoff5093 , Nov 6, 2018 :
    I’m in the same boat. So you tried calling first and they said you weren’t authorized? Did your company rep need to actually make the change or just authorize you?
  15. CMSevilla
    Cupcake Nov 6, 2018
    CMSevilla , Nov 6, 2018 :
    I haven't spoken to our rep yet, since I work for a nonprofit we use a government account and I guess they are limiting in what you can or cannot do on the plan.
    I will be trying to activate a new SIM though and see if that works.
    geoff5093 likes this.
  16. gormanc2
    Donut Nov 6, 2018
    gormanc2 , Nov 6, 2018 :
    I was wondering the same thing. Should I be expecting visual voicemail to be working on this phone though the stock phone app? I'm currently just given an option to call my voicemail phone number the old-school way.
  17. gormanc2
    Donut Nov 6, 2018
    For those who are working currently, does your visual voicemail in the stock OP phone app work? Or is that a
    "The phone associated with the Device ID you entered is not compatible with the Verizon Wireless network. Try a Different Device"
    I'll send you a PM.
    gborbe likes this.
  18. Harley Wilson
    Froyo Nov 6, 2018
    Harley Wilson , Nov 6, 2018 :
    Yeah, rolled all of my 2FA stuff to my Google Voice number because of this, and for stuff that *has* to use the actual phone number (like Whatsapp and Signal), I put my SIM in my old phone to get the code... Luckily, I only talked to three people (mom, dad, and sister) through SMS, so I told them to just use Facebook Messenger. I think I've mitigated most of the issues I'll run into without SMS/MMS, but the 2FA stuff was the biggest pain to reroute. I'm on Xfinity Mobile, so the chances of getting this squared away with them anytime soon is pretty slim.
    S1540827483654 likes this.
  19. BBKoenigsegg
    Cupcake Nov 6, 2018
    BBKoenigsegg , Nov 6, 2018 :
    This is nuts. I appreciate the attention we've received from the dev team thus far, but I really hope this is fixed soon. I want this phone to be my daily driver so badly!
  20. Comixs
    Eclair Nov 6, 2018
